Old 08-07-2002, 03:59 PM   #1
'72 Cheyenne Super
What's it worth? (4x4 TH350)
I've got a buddy bugging me to unload the stock TH350 out of my '72 4x4, and I'm inclined to sell it, but I don't want to have one of those 'DOHHH' experiences after I part with it. The trans has been sitting for a while, and would more than likely need to be completely gone through (although it was working just fine when I took it out). Any thoughts on what it's worth? Thanks in advance!
'72 Cheyenne Super 4x4, 468ci, 700R4, Import Stomper.
A couple pics at http://www.picturetrail.com/gallery/view?p=6&uid=529895&
'72 Cheyenne Super is offline   Reply With Quote
Old 08-07-2002, 04:04 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I would swap you a SM465 with 205 transfer case for it.... Maybe some different parts..... Let me know if you are interested. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-07-2002, 05:05 PM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
'72 Cheyenne Super........I would guess that the value would be comparable to any good used TH350.....$100 to $200. The only difference between a 4wd and a 2wd is the output shaft and the bolt on tail housing.
Wes......too bad you are so far away.....I would yank my rebuilt, 1900 stall, TCI shift kit TH350 for a SM465/NP205 set-up any day.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 08-07-2002, 05:05 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
When I went to rebuild my transmission and discovered that my case was cracked, the guy at Kirkland Transmission said that he charges $450 for a true 4wd TH350 "K" case, if he could even find one. I shopped around and I bought a core at Olympic 4x4 in Snohomish for $125 with a "K" case. I saw a "K" case for sale on CK5 for $300 with the flywheel cover. If the thing needs rebuilding, your really just looking at selling it as a core, maybe a few parts, it is worth in the $125-$450 range. I'd say that Wes is offering you a pretty fair deal.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-07-2002, 05:33 PM   #5
'72 Cheyenne Super
Thanks for the responses! Wes, I don't have a need for the SM465 or the NP205 (although, I would like to build a stout transfer case for my truck someday, without having to pull mine out and wait for it to be overhauled before it's back on the road again). I might try to hook up with you in the near future to see what you have for swapping. I still need some things for my '72.
Old 08-07-2002, 05:50 PM   #6
Classic Heartbeat
Well if you are looking to change to a manual transmission in your truck the input shaft for your 205 is different as is the adapter for it. You can get a replacement sleeve from advanced adapters thow also and a new adapter also. WES www.classicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 08-07-2002, 06:24 PM   #7
'72 Cheyenne Super
Wes, I'm not looking to change anything in my truck, as far as drivetrain goes (see my sig). That's the reason I'm not in the market for trannies/transfer cases. But, I do need to get down to Oly to support a board member!
Old 08-07-2002, 06:38 PM   #8
Classic Heartbeat
AHHHHHHHHHHH!!!!! I SEEEEEEEEEEEE!!!!!!! We need to talk!!!! WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 08-07-2002, 07:58 PM   #9
bouncytruck
SKINNY TIRES RULE!
The 4x4 cases are slightly different than a 2wd case. They are thicker at the bell-housing bolt holes and have a full aluminium fly wheel cover. It should have a big "K" on the side of the bell-housing. 2wd cases can be used in a 4wd if you change the the output shaft. I have heard that most of the rebuilts on the market are 2wd cases converted. It might be hard to sell for a lot of $ unless someone is specifically looking for a "K" case. I would try selling it on ColoradoK5 or Pirate4x4.
bouncytruck 1972 K5
