08-06-2019, 02:39 AM | #1 |
292 i6 Questions
Fascinating read here .
Subscribed to find out the end cause .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-06-2019, 09:35 AM | #2 |
Who Changed This?
Re: 292 i6 Questions
It's a stumper, for sure.
08-06-2019, 11:46 AM | #3 |
Off Idle Flat Spot
I've been an i6 engine lover since the early 1960's and I wish this one wasn't so far away .
I've been able to make clapped out InLine engines with 60# compression run very well . This one clearly has some internal issues but, judging by the spark plugs it's running way too rich, apart from the oil wetted # 2 one . There's a bit of art to tuning the InLine engine, I think perhaps he still has some sort of vacuum leak .
08-06-2019, 12:13 PM | #4 | |
Re: Off Idle Flat Spot
I do want aftermarket AC and power steering eventually. Ive seen a few pictures of some rigs with both, definitely not as clean as a v8 or as common. Haven't found a bracket kit for sale that looked legit, saw one on ebay that looked interesting. Ive also seen some videos of a guy who put a 5 speed on his 292 and it looked like a smooth ride. The 4 speed with a granny gear I have is cool but not too smooth for what I do and Ill never need a granny gear like this has. Those are really the only "things I am not sure about" with keeping the 292. Its obviously possible but im not too good with this stuff. Thanks for joining in. |
08-06-2019, 04:33 PM | #5 | |
i6 Fiddles
I'm a geezer who had GM factory training and was Dealer Mechanic when these were current production . The order in which you do things is critical to avoid chasing your tail . That it ran well once and began smoking tells me the engine per se is prolly just fine . Not having deep pockets is a problem, join the club . Not knowing what you're doing is less of a problem because many here are well learned and have experience working on and with these old rigs . Each one degree of dwell change alters the ignition timing by 3 degrees, more than one degree is a _lot_ although most doesn't realize it as they simply stomp the throttle and make noise and smoke over revving the engine . My last 292 would foul the spark plugs in 250 miles plus it was a 1976 GMC and so needed to pass smog testing, I peaked and tweaked it, had to go to a $45 junkyard HEI from a 1977 Nova and open the spark plugs up to .070" before it stopped fouling plugs, then it " flew through the test " (quote from my smog guy) even though it still burned oil and you'd smell the burned oil out the exhaust.....
