Old 11-11-2015, 07:24 AM   #1
bill3rail
bill3rail's Avatar
No SPID Plate, can I get some ideas on what I have here?
I bought this '70 C10? With State issued vin#. I want to figure out what if any options I have here.
The Inline 6 and 3 speed are easy for a newcomer like me to figure out.
I am about to re-gasket the rear end so I will check the gear ratio when the cover is off.
What other items should I be looking at?
Thanks,
See pictures here. http://2212.ecarlist.com/web/ebay_photos/21857452/
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 11-11-2015, 10:06 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: No SPID Plate, can I get some ideas on what I have here?
Thanks,
I am assuming they repainted the glove box door and removed the SPID label in the process. With all the changes that I see to the truck I don't think it would do you much good any way.
It looks pretty clean in the photos. I would just do the basics like checking the condition of the steering linkage / ball joints / idler arm and check the condition of the brake shoes / wheel cylinders / axle seals plus all the fluid levels.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-11-2015, 10:12 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Thanks,
Unless there is a build sheet under or behind the seat (in the springs) you are probably out of luck with no SPID.
The ring and pinion tooth count chart is in post #2 in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 11-11-2015, 05:32 PM   #4
sventinker
Factory power steering too! I would like to see a picture of the power steering lines where they cross over the frame if you wouldn't mind. Nice truck
sventinker is offline   Reply With Quote
Old 11-11-2015, 06:01 PM   #5
john
member #16
john's Avatar
Besides the power steering , which most six cyl's did not have you also have the optional wood bed floor, Looks like a very nice truck. The full gauge option would have been listed on the SPID.
john is offline   Reply With Quote
Old 11-11-2015, 10:28 PM   #6
bill3rail
bill3rail's Avatar
Yes, the glove box door has been repainted. Not very useful? I am just curious if there are any things to look at to identify. What changes do you see?
The truck is very clean! Steering is tight, Getting ready to convert to front disc brakes with new ball joints and some tie rod ends, Will inspect the rear brakes/cylinders/axles when she's in the air. Fluid levels are already checked.
Thanks,
Old 11-11-2015, 10:32 PM   #7
bill3rail
bill3rail's Avatar
LockDoc
I didn't know about build sheets, I will be removing the seat because I wanted to replace the cable anyway.
Thank you for the link, I read that one once before, but failed to save the link.
Old 11-11-2015, 10:34 PM   #8
bill3rail
bill3rail's Avatar
I will try to get a picture over the weekend of the PS lines for you.
Old 11-11-2015, 10:37 PM   #9
bill3rail
bill3rail's Avatar
No Vac or tach on the dash. Aftermarket added under the dash board. I moved the tach to the steering column.
I'm adding power front disc brakes to the power steering this winter to make my knees last longer!
