Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-11-2020, 05:29 AM   #1
Daze57
Daze57's Avatar
solenoids
hey guys
i have shaved doors on my 57 and i want to do the solenoid thing .
i have heard the old school way of using gm starter solenoids .
has anyone gone this route? i understand there are pretty good companies that make complete systems with there own solenoids---dont need that i just need 2 good strong ones.
I have the bear latches- and my doors are tough to release the latch - any suggestions would be great
Dont know if there is a different wiring set up for the GM"s just looking for good strong solenoids . Diagram would be nice too
daze57
Daze57 is offline   Reply With Quote
Old 11-11-2020, 09:02 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: solenoids
Yes many years ago. Sounds like your latches aren't aligned properly though. Bear Claws are usually very smooth. I have them on my 64 and it's they are feather light to open. Only one finger to close the doors.
Old 11-11-2020, 12:08 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: solenoids
Most solenoids are tough depending on how they are used. Typical wiring is the same for all of them. Solenoids are 2 systems in one unit. Activation side and the power side are the side that does the work. Activation side is the 2 small terminals. These 2 small studs activate the solenoid to pull the coil in so the 2 bigger studs can send power to something that requires a lot of amps.
Here is a quick drawing I did in paint. I'm not artist so bare with me. The solenoid for a car is typically 12 volt DC activation and less than a 100amps. most times. Depending on the popper rating you have you will need to get one as close to it as possible, preferably a little more than it's rating. This link is for a 12 v DC 100amp solenoid Continuous.
Hope it helps you out.
https://www.grainger.com/category/el...&filters=attrs
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-13-2020, 05:42 AM   #4
Daze57
Daze57's Avatar
Re: solenoids
thank you guys very very much ---good information
