11-24-2020, 10:25 AM | #1 |
Fuel Sender Question ?
I plan to keep the gas tank in the cab of my 64.
I purchased a set of aftermarket gauges, and the fuel gauge is 0-90 OHM. I know that the sender for 1964 is 0-30 OHM. Can I replace the sender in the tank with a 1967 unit (0-90 OHM), as the tanks dimensions seem very close. |
11-24-2020, 11:52 AM | #2 |
Moderator
Re: Fuel Sender Question ?
Ya with those gauges the original sender would not work. Although I'm not at all sure the 67 sender fits. I'm sure someone will chime in soon on that.
11-24-2020, 10:42 PM | #3 |
60-66 Nut
The '67-'72 fuel sender mounts to the tank differently than the '60-'66 fuel sender. You could combine the two to make one.
11-24-2020, 11:53 PM | #4 |
I can't seem to find where I bought mine, but Jegs lists one that supposedly is 90 ohms - might call and confirm ?
Jegs / Key Parts : Part Number: 576-0848-790U
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
11-25-2020, 04:54 PM | #5 |
Went through this on a buddies truck a couple years back. We ended up removing the little resistor box off of a 67-72 sender and installing that on the earlier fuel sending unit. That way it used the correct later style 0-90ohm setup.
1965 Chevy C10 283 SM420 Long Fleet "The Old Man" 1970 Chevy C10 350 SM465 Long Fleet "Dave" 1975 Toyota FJ40 "Mr Grinch" 1969 Pontiac Firebird 2001 Chevy Tahoe 2001 Toyota 4Runner |
