Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-07-2020, 10:09 PM   #1
kaycee
kaycee's Avatar
Adding Acc.
So I just got done adding power windows in my 69 and added a relay from the battery to power them . Now I have a amp ,and relays for my electric fan and the heavy duty head light harness with relays all powered off the battery. is this OK just looks like a mess at the + terminal on battery. The windows have a power wire to the relay then a short wire over to the fuse box ign. fused . Just want o try and clean it up some ,everything works great just paranoid I guess plus my wiring skills are not my strong points. Oh yeah how do you tie into a fuse on the fuse block the spade fuses have a little jumper clip but the buss fuses are non existant.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-08-2020, 12:19 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Adding Acc.
You can buy a Junction terminal like what's on the fender beside the battery and run everything off of it.
https://www.speedwaymotors.com/OER-3...IaAiszEALw_wcB
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-08-2020, 09:52 PM   #3
kaycee
kaycee's Avatar
Re: Adding Acc.
OK I dont have one on the fender but that is where my headlight relays are.I will check it out and see what/where I can put it Thanks
2005 FXDWG stage3
63 IMPALA 327
Old 11-09-2020, 12:03 AM   #4
Andy4639
Old member
Andy4639's Avatar
There should be a small red wire on a terminal on the passenger side fender right by the battery.
