Old 06-24-2018, 06:38 PM   #1
DJ_Baar
Question Help Installing New Ignition Switch
what am I missing? Feeling real dumb here, have done this on other old vehicles, but cannot figure out my problem here.
I remember only taking-off the small bezel on my '67 Chevy C20. But now cannot get it to go together in my fresh dash. Even got a spacer used on 68 to 72's and no luck. (In picture with old switch.) Its like there is something missing to go behind dash, but my old bezel screwed into the dash, so what kept it from coming thru dash. Maybe the heat today has my head messed-up, but I cannot figure-out this simple delima.
Its an AWW (American Auto Wire) upgrade kit, but old switch and new look the same.
DJ
DJ_Baar is offline   Reply With Quote
Old 06-24-2018, 06:54 PM   #2
bill3rail
bill3rail's Avatar
Re: Help Installing New Ignition Switch
Loc Doc should be stopping by with pictures shortly...
He always does!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 06-24-2018, 07:07 PM   #3
DJ_Baar
That would help - pictures a thousand words. I'm sure its something truly simple I'm missing, but just can't figure this one.
Old 06-24-2018, 07:35 PM   #4
Dustytrix
I think spacer goes behind dash. But Lockdoc will know for sure
Dustytrix is offline   Reply With Quote
Old 06-24-2018, 08:00 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
Bottom pic, part on right goes on part on left. Stuff in from back of dash, install center part, then install lock cylinder
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-24-2018, 08:15 PM   #6
DJ_Baar
Tried. Spacer I have (catalog says for 68 & up, not 67,) leaves NO threads to screw bezel for 67 on to switch.
Old 06-24-2018, 08:21 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
That's because 67 is flat dash while 68-up the switch is recessed.
It's time to do some after factory modifications to your spacer or source the correct parts
Old 06-24-2018, 08:40 PM   #8
DJ_Baar
Todd Rusk hooked me up with this (separate correspondence):
https://www.cooperrestorations.com/p...nition-spacer/
Used only one year, like the shorter bezel.
0849-215 This ignition spacer fits:
1967 Chevrolet Pickup Truck and Suburban
1967 GMC Pickup Truck and Suburban
Measurement 1.5x1x1
Old 06-24-2018, 08:44 PM   #9
DJ_Baar
I assume the flat spot goes UP on switch?
Old 06-24-2018, 10:29 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
You have the wrong spacer. Here is a picture of the '67 only spacer. There is someone on here selling a reproduction of it.
http://67-72chevytrucks.com/vboard/s...d.php?t=747570
The spacer indexes the switch in the correct position. Just make sure the key is vertical.
LockDoc
Leon
Old 06-25-2018, 07:15 AM   #11
DJ_Baar
Smile Re: Help Installing New Ignition Switch
Thank you Lock Doc. It figures 67 was different. I spent a lot of time trying to figure that out & left scratching my head frustrated. Thanks again.
DJ
Old 06-25-2018, 09:58 AM   #12
LockDoc
LockDoc's Avatar
DJ
No problem. The three small tabs you see on the face of the spacer (first picture) fit into the notches in the dash. Also be sure the bezel is started straight, the threads are pretty fine and it is easy to get them cross threaded. It should screw on pretty easy, you shouldn't have to force it.
LockDoc
Leon
Old 06-25-2018, 03:10 PM   #13
DJ_Baar
Thank you again Lock Doc; great feedback and advice.
DJ
Old 06-29-2018, 06:59 PM   #14
DJ_Baar
Yes it makes ALL the difference when you have the right parts!
For the life of me I cannot remember taking off that short adapter or if so where it got put? I do remember taking the old switch out because the whole wire harness and fuze panel were GONE (fuzes rusted in place - amazed I could drive it).
Thank you all for your feedback.
DJ
Old 06-30-2018, 09:11 AM   #15
LockDoc
LockDoc's Avatar
DJ
Good deal. Glad you got it all sorted out.
LockDoc
Leon
Old 07-03-2018, 08:45 PM   #16
DJ_Baar
Just a follow-up.
Pictures show the ignition switch flat spot goes to bottom toward back of dash and labels on contacts can be read right side up to correctly get the key vertical when done.
Just wanted to clarify that for any future readers.
Old 02-01-2021, 07:04 PM   #17
TrkEnvy
Has anyone ever had a problem with the key not coming out of the lock cylinder once it’s installed in dash? I’m not sure what I’m doing wrong but key won’t pull out when turned to off position..
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 02-01-2021, 07:08 PM   #18
TrkEnvy
Never mind. I re read thread and I had it upside down. Thank you.
Old 02-01-2021, 09:05 PM   #19
LockDoc
LockDoc's Avatar
Glad you got it figured out. They can be a pain sometimes.
LockDoc
Leon
Old 02-02-2021, 08:39 AM   #20
Stover93
DJ
I have the same problem about putting parts away for safe keeping. When I do that I may as well pitch them in the trash instead cause they’ll likely never be seen again either way!
Stover93 is offline   Reply With Quote
Old 02-02-2021, 10:03 AM   #21
LockDoc
LockDoc's Avatar
Unfortunately that's not the parts fault. If you could see my shop you would know why....
LockDoc
Leon
