09-12-2009, 09:52 PM | #1 |
1/2 ton brakes
Is there any easy way to to upgrade my drum brakes to the 3/4 ton size? Or would i be better off just getting a new frame or just a bigger truck?
09-12-2009, 10:25 PM | #2 |
laying low
Re: 1/2 ton brakes
How bout lookin into a rear disc setup instead for your 1/2 ton rear? There are some aftermarket kits and some guys do the salvage yard swap using Caddy Seville parts. There are some threads here on this and you might find something in the FAQ section as well.
09-13-2009, 12:06 AM | #3 |
Re: 1/2 ton brakes
Buy a new disc conversion kit. Will save you time and money in the long run.
09-13-2009, 01:12 AM | #4 |
its all about the +6 inches
Re: 1/2 ton brakes
are you trying to make your truck a 3/4 ton... or just want better brakes?
Also, what is your brake set up now? |
06-28-2010, 09:27 PM | #5 |
Re: 1/2 ton brakes
I just have drum brakes. I want better brakes and handling with heavy loads.
06-29-2010, 01:45 PM | #6 |
Re: 1/2 ton brakes
if you need a 3/4 ton truck, I'd say get a 3/4 ton truck. They are normally pretty cheap becouse everyone wants a 1/2 ton.
I'd bet there's more than a few guys here with C/20s that'd trade for your C/10 |
