11-06-2016, 07:47 PM | #1 |
New AC Delco Seide terminal Battery Cables
SOLD
Bought these from a member for my 76, but they aren't the right ones for my 76 apparently. Pls look closely at the pics - note that both ends of the (+) batt cable have the side-terminal connection, as if it were to connect to a junction block or another batt, or something. I ran the part number on the positive, and several applicacations popped up, but the most common was mid-late 80's 6.2L Diesel C/K/R10/20/30. Anyway - if it LOOKS like what you need, these are high quality AC Delco cables. $40 shipped conus. EDIT 11/10: $30 shipped. Last edited by jocko; 12-08-2016 at 01:28 AM. |
11-11-2016, 01:08 AM | #2 |
Re: New AC Delco Seide terminal Battery Cables
still available -
11-19-2016, 03:39 PM | #3 |
ttt
12-03-2016, 02:58 PM | #4 |
bump
12-05-2016, 08:52 PM | #5 |
what is length of positive?
12-05-2016, 09:21 PM | #6 |
I will take them-looks close enough! your paypal address or?
12-05-2016, 09:39 PM | #7 |
I can measure them if you like - but not until this weekend. Regardless, you are first in line. Will pm PayPal info - but you are more than welcome to wait until I get a chance to measure.
12-07-2016, 10:33 AM | #8 |
put me 2nd in line -pending length ??
12-07-2016, 03:32 PM | #9 |
Payment received (favor). PM sent. Thank you.
03-12-2017, 01:44 PM | #10 |
Darn missed out on the that one (dual batt set up)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
