10-30-2012, 10:02 PM | #1251 |
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
I don't have the CPP kit, but I do have the McGaughy 13" kit (same hub and rotor) and my 1st Gen wheels fit without issue.
Posted via Mobile Device |
11-17-2012, 04:29 AM | #1252 |
Brandon's Truck.
These wheels are work to make them fit, but it is SO worth it when done correctly! Here is some motivation for you all.
I LOVE BURNOUTS:metal NO BOZO's |
11-17-2012, 12:29 PM | #1253 |
Finally got around to taking a pic with my 338
245/40/18 and 275/30/20 Nitto's. I do have 2/4 drop springs to install so that should help, but I think I need a 294/45/20 rears.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-17-2012, 12:44 PM | #1254 |
11-19-2012, 05:01 PM | #1255 |
Did this. Ground rotors up front. Spacers in rear. Measure 3 times before ordering spacers if you want it tight. 20" wheels, 10" wide in back with 6.23 bs, 8.5" wide in front with 5.24 bs.
J&S Sideyard Projects......we will be at...... Dino's 3rd annual Pre-ShowGit Down |
11-19-2012, 05:38 PM | #1257 |
Great looking ride and wheels!!!
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
11-27-2012, 08:21 PM | #1258 |
so without reading through 50+ pages of jibber jabber, can someone confirm or deny if the new wheels do or do not fit '72 front rotors without having to grind the hub?
11-27-2012, 08:35 PM | #1259 | |
67-72 parts collector,…
You will have to grind the hub. Period. Just like in the picture. (4 posts before this one).
11-27-2012, 08:47 PM | #1260 |
11-27-2012, 08:51 PM | #1261 |
very nice! is that a narrow rearend or the wider 71-72? where did you get the spacers from and what size did you use on it?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
11-27-2012, 08:53 PM | #1262 |
I personally would rather have the 5.25" BS on a 8.5" wide front wheel.
12-04-2012, 02:40 PM | #1263 |
Finally scrounged enough cash together to get everything done. Looks pretty good. Now to lower the rear 1-2". I need functionality so no more dropping for me. 20x8.5 front 20x10 rear.
12-04-2012, 04:39 PM | #1264 |
What size tires are you running?
12-05-2012, 12:48 PM | #1265 |
I am running 275 45 20 tires all the way around. I was going to stagger the front width but decided to just get a narrower wheel. I did not want directional either. I like to rotate my tires. At least side to side is better than nothing.
12-16-2012, 08:14 PM | #1266 |
Specs:
Narrow rearend 5 1/2" Backspace Boss 338's (rear) Toyo Proxes II's 295/40R20 1" hub centric spacer from here. https://www.ezaccessory.com/ProductD...ode=5500-5500P
12-17-2012, 06:17 PM | #1267 |
this 67 truck has the 71-72 rearend which, like you know, is wider.
12-17-2012, 08:15 PM | #1268 |
Your truck is sweet, I like it alot.
I'm not as good as I once was, But I'm as good once as I ever was. Last edited by big mike71; 02-24-2013 at 08:06 PM. |
02-24-2013, 05:35 AM | #1269 |
4 years after buying them my 18's are on and my 69 has 5-lug power disc brakes. What a difference.
Posted via Mobile Device Posted via Mobile Device |
02-24-2013, 07:09 AM | #1270 |
4 years! I would have gone crazy looking at them that long... Looks good and I guess they fit without issue?
02-24-2013, 02:23 PM | #1271 | |
02-24-2013, 04:35 PM | #1272 |
TNT-MOTORSPORTS
Ttt
03-01-2013, 09:14 PM | #1273 |
TNT-MOTORSPORTS
Ttt
03-01-2013, 09:22 PM | #1274 |
my buddy is looking for 20's in a 338 8.5 up front (5.25 offset) and 10's (5.5 offset) for the back.....chrome
03-01-2013, 09:42 PM | #1275 |
TNT-MOTORSPORTS
see vendor section or call 918-845-1935
