11-24-2017, 01:12 AM | #1 |
SM465 PTO options?
The truck is a 1985 C60 2WD. Equipped with 5.7 and the 4 speed (SM465?) - 2 speed rear end. What are the PTO options for this transmission? Some part numbers will be appreciated.
Crawl, walk, run, fly... what's next? |
11-24-2017, 10:15 AM | #2 |
Re: SM465 PTO options?
Chelsea is the only one I've ever heard of google "Chelsea PTO"....ebay will probably be your best bet to find a good used one....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-24-2017, 12:02 PM | #3 |
Great! Thanks.
11-24-2017, 01:21 PM | #4 |
Call these guys, they can build whatever you want. Right hand, left hand, front, back, etc
http://www.sixstates.com/products/products.jsp |
11-24-2017, 02:30 PM | #5 | |
After a few hours of research, I've found some information here. Some one suggests the 340 and 352 series Chelsea PTO should mesh just fine.
Crawl, walk, run, fly... what's next? Last edited by 1971'Burb; 11-24-2017 at 10:33 PM. |
11-26-2017, 10:15 AM | #6 |
Just start checking junk yards or even local clist. Tons of old square body’s floating around with ptos left on them.
What setup are you looking for? Lots of the early setups were ptos that drove a small Driveshaft. Later one seems to be direct pto mounted hydraulic pumps. |
11-26-2017, 12:09 PM | #7 | |
11-27-2017, 02:52 PM | #8 |
One of the First
If the PTO is used on a rear apparatus. It will probably need a least a 8 in straight shaft coming out of the PTO case. Most attaching shaft yokes have clearance issues with the transmission case if the output shaft is shorter than that.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
11-27-2017, 03:50 PM | #9 | |
Hoping I have no major issues at 540rpm. Still doing research. Looks like I'll end up with about 9 feet long shaft under my single cab dually.
11-29-2017, 02:15 AM | #10 |
11-29-2017, 08:15 AM | #11 |
try to keep the drive shaft to the pump as short as possible and simply use longer hydraulic lines...that way you won't need pillar block bearings and all the excess moving parts..just plumb the high-pressure lines to whatever you intend to power.....a couple of valves and you're all set...
11-29-2017, 10:41 AM | #12 |
One of the First
Your going to have a keyed stem shaft coming out of PTO unit, make sure it clears transmission case. Then you will attach the longer shaft to the PTO and hydraulic pump. That's when you get into yokes, pillar bearings, angles, etc...
