Old 01-28-2010, 01:38 AM   #51
dan468
dan468's Avatar
Re: Installing a T-56
Originally Posted by 68jewel View Post
The T56 only comes as a hydraulic clutch setup. Yes......
1. You will have to reinforece the firewall to keep the clutch pedal from pushing thru.
2. You will have to modify your trans tunnel/hump and relocate the tranny crossmember.
3. Buy an adapter plate for the bellhousing if you don't have an LS(Gen III/IV motor)
4. Hook up a clutch pedal for the clutch.
5. Shorten your driveshaft
6. Change your rear gears, because if you don't 6th gear may be virtually unusable.
There's a few other small variables in there, but that's pretty much it.
Do you have to reinforce the firewall if you use a hydraulic throwout bearing?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 01-29-2010, 02:44 PM   #52
nzjkb5
The reason for reinforcing the firewall is that the clutch master cylinder mounts to the firewall. It won't matter whether you have a hydraulic release bearing or an external slave cylinder. I personally don't know that your truck requires reinforcement, but I know that some cars do. I think it would be a good idea.
nzjkb5 is offline   Reply With Quote
Old 01-29-2010, 03:40 PM   #53
dan468
dan468's Avatar
Cool, sounds easy enough anyway
68 C-10
Build thread
Old 01-29-2010, 05:20 PM   #54
68jewel
On the path to financial ruin!
68jewel's Avatar
Trust me, you will have to reinforece the firewall. Older cars firewall metal just isn't thick enough. Have I done a transplant on every old car?...NO. But, I haven't met anyone who didn't reinforce the firewall either. I personally have done one on my Chevelle though. I guarantee you will need the reinforcement. Besides, why wait to try it without reinforcement just to see what will happen.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 01-29-2010, 07:49 PM   #55
dan468
dan468's Avatar
I'll post pics of the transplant as long as the creater of this thread doesn't mind. It seems I'll be using a kit from this site:
http://www.weirhotrodproducts.com/id3.html
Contrary to what the site says they now sell a matching master cylinder to go with the kit.
68 C-10
Build thread
Old 01-30-2010, 03:12 AM   #56
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
was thinking on using this CCP 60-62 chevy master cylinder with hyd master clutch when i was installing my Borg/Warner T-5 in my 68. I ended up using the stock linkage for now just to get it running!!
But if get the cash i will have to try it out to see if it will work! and yes i know its for a 60-62 but you never know it could work!!
Name:  brake booster.jpg
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 03-30-2014, 05:31 AM   #57
smoky02
Location: Sunny, Florida, some might call it South Alabama
I ended up not buying the T-56 way back then. I did recently purchase a TR6060 and will be installing it when I get home from this glorious sandbox.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 03-31-2014, 05:33 PM   #58
ulakovic22
Holy ressurrection! A T56 will work in our trucks. You move the shifter forward to the inspection cover, new trans xmember, cut the floor back to the ridge and convert your clutch pedal to use a MC. You will have to lengthen the clutch line though from the master to the slave since the stock one will be too short. If using a LT1 T56 it will bolt up just fine, an LS1 requires an adapter plate although I have heard that 5 of the 6 bolts line up even if you don't.
Anthony
'67 Shortstep (555/T56)
'67 Parts Truck (TBA)
ulakovic22 is offline   Reply With Quote
Old 03-31-2014, 08:50 PM   #59
trkfrk
trkfrk's Avatar
The T56 comes with the LS1.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-31-2014, 11:35 PM   #60
ulakovic22
It also comes with the LT1 in f-bodies from 93-97 and also in a slightly different configuration with Vettes and Vipers. What x-member are you using with yours? Have you measured pinion angle yet and do you plan to move your shifter the the inspection cover?
Anthony
Old 04-01-2014, 09:59 AM   #61
trkfrk
trkfrk's Avatar
I don't remember off hand the brand of crossmember I used. When I get home I will check my paperwork and let you know. Yes, I string lined from the yoke on trans to my yoke on the piņon to check angle and make sure the driveline clears the center support on my frame, especially since I installed a 4" x 6" suspension drop. I plan on leaving the shifter in the rear of the trans and not using the relocate kit. I want it to shift like a car with a close ratio shift patern. I may need to notch my seat or make a custom shifter.
Mark
Old 04-01-2014, 10:07 AM   #62
trkfrk
trkfrk's Avatar
Pic 2.
Mark
