01-15-2021, 01:17 PM | #1 | |
Re: NV4500 swap installed and rollin!
https://www.pirate4x4.com/threads/sm...-np205.519198/ It appears you have one of the rare desirable 32-spline np205 cases with the round six-bolt pattern. A nv4500 is virtually the same length as a sm465, if both are 4wd. There are slight differences of less than 1/2 an inch, but as far as I know, that's just manufacturing discrepancies over the years. It's not enough to cause any issue with driveshafts. A potential issue is the transfer case shift linkage. The nv4500 never had the connection point for the transfer case shift linkage that the np205 requires. You'll need to fab up a bracket, or buy one. It appears that Advance Adapters makes, or did make, a bracket for that purpose. Edit to add: be sure to look over any nv4500 good before installing it. Ideally even before buying it. Remove the shift cover, the pto plates, and the rear extension housing. Look for any debris in the oil, check for excessive slop in the input shaft/mainshaft combo, make sure there are no chipped or badly worn gear teeth, and confirm that the fifth gear nut and gear are still in their correct locations. It's also possible to tell the general condition of the synchros, just by looking at the spacing between the sychro teeth and the engagement teeth. I'm not well versed on that, though. I bought a 1997 nv4500 sight-unseen, and intended to stab it in and run it as-is. I opened it up, and found that fifth gear was half-way backed off, the input shaft thrust bearing was gone, the 3/4 synchro hub was trashed because of that missing bearing, the parts of that bearing had chipped two gear teeth, and the synchros were heavily worn. I'm facing $1000 in parts to get this thing back in operable condition. If I had run it as-is, it most certainly would have failed in the first 100 miles. These nv4500's are not hard to work on, if you have access to bearing pullers, a press, and basic fabrication tools for making some of the specialty tools required.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 01-15-2021 at 01:26 PM. |
01-16-2021, 11:47 PM | #2 | |
$1000 in parts? I'm fixing to rebuild my spare nv4500 at about half that price from Allstate. I wouldn't buy a used trans without assuming it needs rebuilt. Although I got lucky on my current one I just installed but I was able to drive the donor truck before he pulled it. |
02-02-2021, 06:05 AM | #3 | |
100:1 low gear! Last edited by doubleclucker; 02-06-2021 at 06:49 AM. |
02-02-2021, 08:38 AM | #4 | |
Are you sure the extra 1.5 of length didn't show up in the t-case swap? I've had my hands on three transmissions simultaneously; a 4wd sm465 with the factory hydraulic bell, a 1993 4wd nv4500 with the factory external slave bell, and a 1997 4wd nv4500 with the factory internal slave bell. All three measured within a half inch of length from the engine block to the transfer case mating surface. The trans mount point was the same as well.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
11-15-2020, 12:05 PM | #5 | |
(I know you're asking "Why?" but I use it more off-road than on the highway so the granny gear would be more useful than the overdrive)
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
11-15-2020, 12:35 PM | #6 | |
The squarebody iron-tops will need floor modifications, custom slave cylinder plumbing, and possibly exhaust rerouting to clear the slave. Also look for the 1992-1994 nv4500. These years had the granny gear and the overdrive. The granny isn't quite as deep as the sm465, but it's close. These should drop right in, but you might have to change the transfer case input shaft. Again, you'll want to purchase an nv4500 complete with a bellhousing. I might be winging it a bit here. I'm confident in my information regarding the nv4500. I'm less certain about my knowledge of the nv3500. Keep that in mind with the following paragraph. The R/V trucks continued to offer the iron-top sm465 as the only manual option through the end of their run in 1991. The gmt400 trucks started out with the nv3500 in 1988 on the half-tons. The heavier trucks got the aluminum-top sm465's with the rearward shift position and passenger side slave. This shift position and slave position were identical to the nv3500. In 1992, the sm465 was dropped for good, and the nv4500 showed up on the scene. This was the same length, the same shift position, and the same slave position as the lighter nv3500 and the now-discontinued aluminum-top sm465. My knowledge of the nv3500 drops out at this point. The nv4500 continued in the granny-low configuration through 1994. In 1995, it was rearranged to match the Dodge nv4500 ratios. Granny low was dropped, and all the gears were spaced better for daily driving. In 1996, the bellhousing to trans bolt pattern was changed to match the dodge bolt pattern. At the same time, a new internal slave bellhousing was introduced. A few more minor changes followed in 1997 and 2001, but those don't affect fitment much. In summary, any manual transmission from a gmt400 should be interchangeable with any other, until you get into the mid-90's with the internal slaves. The aluminum-top sm465, the nv3500, and the nv4500 can all be switched. Just make sure each one comes with it's respective bellhousing. The bellhousing has to stay with the respective transmission. Also, the spline counts on the t-case input shaft might change between the lighter weight trucks and the heavy weights. The input shaft on a np241 is a very easy and cheap swap, though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! Last edited by kipps; 11-15-2020 at 12:44 PM. |
11-16-2020, 01:22 PM | #7 |
Okay, thanks!
That tells me just any old 465 won't fit; has to be from a GMT400. So I will just go back to my original plan: eventually try to find a decent 73-87 K/20 with an SM465 for my "ranch" truck. I get pretty tired of putting the 89 K1500 in low range any time I need to back up a little hill, or do anything slow and careful
