Old 03-10-2019, 02:17 PM   #1
vectorit
What?
vectorit's Avatar
ORD Front upper shackle kit
Anyone have any experience and pictures of adapting this kit to a 67-72?
https://www.offroaddesign.com/catalog/FUSH.htm
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-10-2019, 04:44 PM   #2
Miller's Metal
Miller's Metal's Avatar
Re: ORD Front upper shackle kit
Are you going for a longer spring up front? Here is a pic from (diy4x.com) b52 first gen. It looks like it uses two of the frame holes.
Miller's Metal is offline   Reply With Quote
Old 03-10-2019, 05:59 PM   #3
vectorit
What?
vectorit's Avatar
No, I'm using the existing 4" lift springs.
Do you think this would work out well as a replacement for the OE upper shackle mount? Meaning, do you think after removing the OE stuff this would go in it's place with minor mods?
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 03-10-2019, 07:02 PM   #4
sweetk30
sweetk30's Avatar
the real need for these tends to be hard core offroad flexy guys . otherwise i still run stock on my 73-87 stuff with the poly upgrade bushings and HD shackles with greaseable bolts kit from ORD .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-10-2019, 07:28 PM   #5
vectorit
What?
vectorit's Avatar
This is the only upper shackle hanger I can find.
It's nice, and I'd like to use it because it is bigger and can be greased.
If there was an OE replacement I'd buy that just to get this fixed, and the OE stuff lasted this long so I'd be cool with using it again. But being that they are made of cast iron, and riveted to the frame these are not exactly something that seems to be a part found at the local Napa.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 03-10-2019, 10:33 PM   #6
sweetk30
sweetk30's Avatar
https://www.offroaddesign.com/catalog/hdshackles.htm
just use this kit and NOT change the frame hanger unless there bad and worn out . but you didnt say if they were or not .
Old 03-10-2019, 10:50 PM   #7
vectorit
What?
vectorit's Avatar
The hangers are fine.
It's the piece the bushings push into and the bolt goes through.
Mine is all egg shaped due to someone running with out bushings for years.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 03-11-2019, 12:32 AM   #8
sweetk30
sweetk30's Avatar
anger is on frame .
shackles hook them to the leaf and hanger .
so your riveted on shackle hanger is bad this is common . i have changed a few out .
alternative remove stock hanger and have it bored out and sleeved if you couldn't find a used good one . this would save you from all the extra work of the not 100% bolt in units . not that there not good units . just might save you a lot of hassle.
i just had 4 old bank vault hinges bored and sleeved cheaper than having just 1 hinge remade or new stuff retro fitted .
Old 03-11-2019, 09:58 AM   #9
SunSoaked
SunSoaked's Avatar
That would work fine. I swapped those pieces off of my cucv donor to my 69 k10. I had to reposition my mounting holes slightly but no big deal. If your not changing springs, it should be simple.
SunSoaked is offline   Reply With Quote
Old 03-13-2019, 12:35 AM   #10
OldCreek
OldCreek's Avatar
I took a 67 or 68 2wd frame and used the FUSH to convert to 4wd. No issues from what I can remember but that was over 10 years ago...
Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-22-2019, 05:31 PM   #11
vectorit
What?
vectorit's Avatar
Working on another project, and it really needs the FUSH kit since everything was riding on metal to metal for years. So everything is all oval shaped and can't be fixed with new bushings.
Went ahead and ordered it, and have just received the parts.
Super nice and heavy duty compared to the OE stuff.
Will post updates when I begin and finish this little project.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-25-2019, 12:41 AM   #12
'63GENIII
'63GENIII's Avatar
ORD makes some nice stuff. I used DIYs parts - very similar build quality which is heavier than the frame that they're bolted to. Nice heavy duty stuff!
I have no idea what i don't have more pics of the rear hanger?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-25-2019, 11:28 AM   #13
sweetk30
sweetk30's Avatar
i tend to run a mix of both brands on my builds . both ord and diy4x are super stuff .
Old 08-26-2019, 05:39 PM   #14
vectorit
What?
vectorit's Avatar
This is what I am replacing.
As you can see, there is no fixing this with a new bushing.
More to follow.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-26-2019, 05:46 PM   #15
sweetk30
sweetk30's Avatar
thats way to far gone .
i have seen some get bored and steel sleeve pressed in and bored to size . but these are gone .
your going to get a front end lift just from replacing these and the bushings .
Old 08-27-2019, 08:12 PM   #16
vectorit
What?
vectorit's Avatar
Noticeable improvement, and the truck is starting to sit right again.
Now on to the rear shackles, since they are just as bad as the fronts.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-27-2019, 08:29 PM   #17
sweetk30
sweetk30's Avatar
nice clean looking install job there .
Old 08-27-2019, 08:42 PM   #18
vectorit
What?
vectorit's Avatar
To install these, all that needed to be done was drill 4 new bolt holes and use a die grinder to open up the original bushing hole a little bit.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-28-2019, 11:55 PM   #19
'63GENIII
'63GENIII's Avatar
Very clean indeed. I like the greaseable bolts. If I wasn't a cheapskate, I would have got those as well.
Chris
'63 k15 long step
Old 04-01-2020, 11:26 AM   #20
Last_Paladin
More to follow.
Can I buy these from you?
Last_Paladin is offline   Reply With Quote
Old 04-01-2020, 05:24 PM   #21
vectorit
What?
vectorit's Avatar
No, I already installed them.
You can order a new set from ORD.
Here is a link to their website.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 04-01-2020, 11:56 PM   #22
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I thought he was asking about buying your old worn-out parts. Not sure why though....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-02-2020, 11:18 AM   #23
Last_Paladin
Yeah, I mean the old ones. I want to use them to jig up new ones.
I like how the old ones bolt in two planes on the web and flange of the frame vs how the the aftermarket ones are in a single plane on the web.
Old 04-02-2020, 01:53 PM   #24
CUSTOM/10
CUSTOM/10's Avatar
You can have the ones on my old blue truck, but you have to take the whole truck. Lol
QUOTE=Last_Paladin;8707220]Yeah, I mean the old ones. I want to use them to jig up new ones.
I like how the old ones bolt in two planes on the web and flange of the frame vs how the the aftermarket ones are in a single plane on the web.[/QUOTE]
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-02-2020, 03:44 PM   #25
sweetk30
sweetk30's Avatar
73-up went just on the side and i have never seen one break . seen a lot wear out just like the o.p. had happen on his .
