11-15-2012, 10:22 AM | #1 |
Re: Dug's 1959 Fleetside
Got the front clip lined up. There were a lot of variables to consider. I had to "unshim" the top of the passenger fender at the cab to get the passenger side to line up. Had to slightly sand the body line and paint it (see gold paint) so I could see the body ridge and line it up with the string. Will weld supports in place this weekend and move to cutting out the floor to clear the transmission.
Multiple shots of the driver side core support mount. Heated and bent one of the mounting tabs to line up with the structural piece on the core support. I will need to add some material to the fender liner for bracing since I have cut out so much for the suspension and core support mount. One shot thru the headlight hole so you can see the general clearance of suspension and wheel.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
11-15-2012, 10:24 AM | #2 |
two more shots....
