10-21-2018, 08:00 PM | #1 |
wet sanding primer
Was wondering if any of you wet sand your primer? I'm using a Matrix polyester primer sealer and am considering wet sanding, just because of the dust. I wear either a N95 or a half mask with cartridges, but was thinking the wet sand method might help the paper from clogging. I'm going to let the primer set another day before I start and though I would get some opinions. Thanks
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
10-21-2018, 08:14 PM | #2 |
Re: wet sanding primer
I don't wet sand till I get to 400 grit
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
10-21-2018, 08:45 PM | #3 |
Dan Johnston
I only wet block and any high end painter that is the way they do it...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
10-21-2018, 10:10 PM | #4 |
I've always wetsanded before, but usually wait till base is going on. Gonna try wet method from the beginning this time. I'll try a fender first in case something goes wrong.
10-22-2018, 08:53 AM | #5 |
I have done a few cars and have always used grey lacquer primer. Once the panel has had the body work 99% complete, meaning all the skim putty has been added, smoothed out, and a final thick layer of primer applied, it's then that I start the wet-sanding process (about that 400 grit mark that 67 mentioned). If I find some places that need some more skim putty then I will dry sand that work and prime, then back to wet-sanding. I suppose one could wets sand throughout the whole process, start to finish, but that's a lot of effort and mess to avoid using a mask.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
10-22-2018, 11:05 AM | #6 | |
You can still find lacquer primer? I haven't seen that stuff, with the exception of spray cans, for years!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-22-2018, 02:29 PM | #7 |
Martin Senour (Napa) still makes it and so does 5 Star Extreme (sold at Bumper to Bumper) and Nason. Some call it Acrylic Primer or Acrylic Lacquer Primer. I'm pretty sure it's all the same. My Bumper to Bumper still sells acrylic enamel paints - mixed to match!
10-22-2018, 03:49 PM | #8 |
i stopped wet sanding a long time ago. probly a personal preference but then agian im not a body man. my 72 after i got it home from the paint shop and no wet sanding
10-22-2018, 10:33 PM | #9 |
Not wet sanding the high build ply primer, wet sanding the poly/sealer. Dont ask the difference because I don't know myself. The high build poly is mixed with a small amount of activator. While the other has the normal activator and reducer , but according to the tech sheath it can be wet sanded. Personally I like the wet sand method. I have a mess on the floor I can mop up, the dry sand has dust everywhere and covers everything. Just wanted to know what others do or have tried.
10-22-2018, 11:15 PM | #10 | ||
10-29-2018, 02:16 PM | #11 |
Bucket of hot water and heavy rain is the only way to sand. 220 then 320
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-30-2018, 06:42 AM | #12 | |
10-30-2018, 06:47 PM | #13 |
I am currently painting my 71 right now and have had some great success so far ..wet sanding is time consuming and puts water on possibly unfinished body panels(exposed steel) which later might expose a rust problem later
I am finishing up my Truck this fall and have found that a good final paint finish does not require a wet sanded finish. I use urethane primer my final sanding on the primer is done with 320 sand paper, then a final overall scuffing or smoothing is done with my Scotch-Brite pad. I so far have finished about half my truck and and it looks amazing..I do plan on wet sanding and buffing...but not prior to final paint and clear coat |
