02-07-2019, 01:20 PM | #1 |
Looking for pics 5/6 rear coil drop
Im undecided on my rear drop, not wanting to c-notch. Wanted to see if any one could post any pics of how much room you have from the axle to the frame you have with your drop in the rear. I have a swb with a missing wood floor. My truck is not a daily. Any pics are appreciated.
02-07-2019, 01:43 PM | #2 |
Almost Satisfied
Re: Looking for pics 5/6 rear coil drop
Sorry I don't have a pic to post to show you, but I am running the ECE 6" drop spring and don't have a C-notch and don't need one. Talk to Early Classic and they will guide you. I'm sure if I slammed a speed bump or something I would hit the rubber stops, but I plan to go slow...over speed bumps.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-07-2019, 02:34 PM | #3 |
ECE 6" drop coil springs in the back, no notch. its about 3" between axle and frame.
i wanted the spacing between the tire and fender curve to be equal the whole curve. it is... hard to see in pic. http://67-72chevytrucks.com/vboard/a...1&d=1548989450 |
02-08-2019, 10:02 AM | #4 |
02-08-2019, 09:23 PM | #5 |
six inch drop ...maybe when I put the fleet side bed with wood floor and cab back on it drops a hair more ?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-08-2019, 09:31 PM | #6 | |
02-09-2019, 04:50 PM | #7 |
Thanks for the pics, and comments everyone
02-09-2019, 11:40 PM | #8 | |
just measured 2.25" between frame and axle. not sure why mine is so low. good thing i dont plan on towing. honestly just got it together havent driven it on the road besides around the block. could always add an inch block if i bottom out more than i like. (before i get around to c-notch) |
