Old 05-13-2013, 11:30 PM   #1
toothenator
toothenator's Avatar
Rear control arms
I'm starting to turn my 88 c1500 into a performance street truck and the first step is building a solid rear end. I plan on using the stock 8.5" 10 bolt but I plan on converting the suspension to a coil over set up and mounting some upper and lower control arms to the differential/axel housing. Since the rear end was not originally equipped I'm having a tough time finding them designed for the truck. Any suggestions other than just custom fabbing some adjustable ones in??
toothenator is offline   Reply With Quote
Old 05-14-2013, 12:23 AM   #2
Kim57
Kim57's Avatar
Re: Rear control arms
Here are a few links to 4 link set ups.
I would think any could be done with coil overs.
http://store.gaugemagazine.com/88-98...on4link-1.aspx
http://www.ebay.com/itm/88-98-Chevy-...-/350572088113
http://www.ebay.com/bhp/4-link-chevy-truck
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-14-2013, 12:46 AM   #3
toothenator
Thanks. using 4-link instead of control arms or trailing arms completely altered my search results.
Anyone here have a preference on axle brands for an 8.5"10 bolt to hold about 450 hp??
Old 05-14-2013, 07:39 AM   #4
OrangeAnimal
OrangeAnimal's Avatar
Moser.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 05-14-2013, 09:44 AM   #5
toothenator
Any specific axles you have used and how much horse power do you have behind them?
Old 05-14-2013, 05:31 PM   #6
OrangeAnimal
The moser axles were in a El Camino with a 400sbc 10 bolt rear end. I have no idea how much power the car made. If I had to guess I would put it conservatively at 425hp and close to 500tq.
I also had Superior Axles in a Mustang with a 8.8 rear end. Engine made 415hp/455tq. So they saw use everyday.
PS I would make sure you do a very detailed build of the 10 bolt. Also get a cover with bearing supports in it. It can break the caps no prob.
Old 05-14-2013, 08:26 PM   #7
Kim57
Kim57's Avatar
IMHO if you plan on putting any power to this project I would think about stepping up to 12 bolt or 9" with 31 spline axles. They should still be in abundance in the bone yards.
Kim
My build thread
Old 05-15-2013, 02:17 PM   #8
toothenator
I am considering changing the whole rear end but I keep reading that the 8.5" 10 bolt rear end can handle platforms with < 500 hp no problem
88 C1500 MODERN CLASSIC
96 HARLEY FATBOY OLD SKOOL
differential, performance
