Old 01-20-2021, 05:50 PM   #26
MikeB
MikeB's Avatar
Re: Trying to do the logical thing.
Originally Posted by James Lamb View Post
Had an old Blazer Chalet I wish I had kept with a TH350 that seemed bomb-proof. But other people have had bad luck with them too.
I've never had any major issues with a TH350. Always minor stuff like fluid leaks and one cracked modulator diaphragm. My last two TH350s, both behind mild 350s, have been bulletproof and mostly leak-proof. Maybe a Gear Vendors OD unit behind a TH350 is the answer!
Speaking of leaks, a cast aluminum pan will fix pan gasket leaks forever. I have also found that worn rubber motor mounts and trans mounts will let engine and trans move around too much, wearing out the shift shaft seal.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-20-2021, 06:10 PM   #27
CC69Rat
CC69Rat's Avatar
LS.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-20-2021, 06:47 PM   #28
SCOTI
SCOTI's Avatar
Originally Posted by CC69Rat View Post
LS.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-20-2021, 09:12 PM   #29
cj847
cj847's Avatar
LS.
If I could trade my like new 350/350 combo for a 120k mile LS/4L60 I would definitely do that.
cj847 is offline   Reply With Quote
Old 01-20-2021, 09:16 PM   #30
CC69Rat
CC69Rat's Avatar
I was kinda kidding, but just saying. For a fuel efficient driver you cant touch it with a carbed small block. The 700r will help, yes but I'm not sure I'd spend the cash to swap it. Tire size and of course shoe size matters too.
I like them all. I'm a BBC guy actually you just cant beat the LS for fuel economy. I'd save my 700r swap money and find a good 6.0 / 4L80.
With respect to the purists if that's your taste, go with it. Just my opinion.
Chad
Old 01-20-2021, 09:45 PM   #31
ChevyRacefan
ChevyRacefan's Avatar
Originally Posted by MikeB View Post
I have to wonder if the reliability issues have to do with improperly adjusted TV cables, which is a very common problem. Or were they known to be unreliable even as installed by the factory?
That said, I'm considering a 2004R for my 69 C10. Low gear isn't crazy low like the 700R4, and the driveshaft doesn't need to be shortened. I'd go with a non-lockup converter.
https://www.cpttransmission.com/catalog.htm
Using o/d without a lock up converter is asking for failure.
Make sure you have a large cooler on that transmission or you will cook it to death in o/d.
ChevyRacefan is offline   Reply With Quote
Old 01-20-2021, 10:30 PM   #32
MikeB
MikeB's Avatar
I'll check with Art Carr first, but do the math. It depends on axle ratio. A 2004R with a 3.73 axle wouldn't be much different than running a 2500 stall converter with a non-lock TH350. But in both cases you'd need an aux trans cooler.
Yes, you still have to install the TV cable correctly, but it's not rocket science. Pretty easy to do, especially with the pan off to make sure the TV lever is just touching the valve with throttle linkage at idle and choke open (no fast idle). In fact, I like a few thousands preload.
Mike
Old 01-21-2021, 12:36 AM   #33
ChevyRacefan
o/d loads the transmission differently, than 1 to 1, and because of this, heats the fluid.
Track vehicle or week end short cruiser. ya, not much of an issue, something you drive a lot, it is a big issue. It gets costly when you burn up o/d gear.
I ran a 2800 (non lock up) stall in a 2004r in a 3.73 geared 26" tall tire vehicle, and when in o/d the fluid temp gets toasty . The transmission would shift into o/d at 45mph, and that speed is much lower than the 2800 stall.
I can only go by what I have seen with the 9 vehicles I have owned with the 2004r. I would not run one without a lock up converter and use o/d for any length of time. A simple switch, and you can have no lock up all you want,, then turn it on when in o/d or just cruising around and don't need the higher stall,unlocked converter .and have the transmission live a long happy life.
Old 01-21-2021, 12:59 AM   #34
MikeB
MikeB's Avatar
I can only go by what I have seen with the 9 vehicles I have owned with the 2004r. I would not run one without a lock up converter and use o/d for any length of time. A simple switch, and you can have no lock up all you want,, then turn it on when in o/d or just cruising around and don't need the higher stall, unlocked converter and have the transmission live a long happy life.
Well, OK. That sounds like some good advice based on your real-life experience.
Mike
Old 01-21-2021, 12:13 PM   #35
siggyfreud
siggyfreud's Avatar
If you do go with a 700R4 check out TV-Made-Ez for Bowtie Overdrives. Their website sucks and half of it isn't working, but if you call them they're super helpful. I'm doing this swap currently just to make the highway manners better until I do my LT swap.
siggyfreud is offline   Reply With Quote
Old 01-21-2021, 01:40 PM   #36
Dad's72
Dad's72's Avatar
Somebody watches Vice Grip Garage. That dude is awesome. A C10 is sitting for 23 years and he drives it home with just the tools you can find at AutoZone.
Dad's72 is offline   Reply With Quote
