06-03-2020, 01:07 AM | #26 |
Re: White Vinegar For Cleaning Parts
I had to clean a nasty fitting off of a sand blaster for repurposing on an impact wrench. About an hour in apple vinegar and rinse. Almost spotless. The fitting was galvanised. Finished cleaned it with a paper towel. As much junk as I have around here you would think I would have a new 1/2"-3/8"npt fitting. Saved a trip to town.
07-01-2020, 08:27 PM | #27 |
Thinking about your thread Doc, I really wanted these bumper nuts badly. I have eight already zinc plated. My rear step bumper didn't have them, but a sport bumper does, which I'm using. At any rate, I had three extra for some reason, & stole another six off my C20. That truck is pretty well rusty, so the nuts took some doing.
I don't like soaking parts in vinegar too long or often. These took three vinegar baths as is, two with a pinch of Must For Rust too. You can help the process with WD-40 baths, which I did, twice , I really wanted these nuts. WD-40 loosens up the rust (black) some, that and a scrub pad works well. First picture is what the nuts looked like after the first vinegar bath, brushing and an oil bath. If it's black it's "still rust" and HARD. That black doesn't bode well for anything short of paint. Second picture is of them finished, but a little sanding in places due. One nut is pretty bad, but I don't need it. Third pic is what they'll look like, though the plated nuts were in much better condition from start.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-01-2020 at 08:54 PM. |
07-01-2020, 09:06 PM | #28 | |
The Older Generation
I've had a couple of parts that I had to get a little more aggressive with too. I used the wire wheel on one of them and it worked pretty good. I have a few of those slotted nuts if you want me to see if any of them are in good shape. LockDoc
07-01-2020, 09:35 PM | #29 |
Well there ya' go. After you get your parts clean, you can have greens.
07-01-2020, 09:53 PM | #30 |
Gave that stuff a whirl. 1 buck at the Dollar Store. All I can say is I am impressed!
Let em sit in the sun with the lids on. |
07-01-2020, 10:28 PM | #31 | |
Messing around, seriously I'm good, thank you for the offer. Then again, if they're nice and you don't need them, I'll find some bolts for your good gesture I call em slotted nuts too - apparently they're "expanding flex top" or "flex lock" nuts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-03-2020, 10:18 PM | #32 | |
07-03-2020, 10:34 PM | #33 | |
No problem. Thanks for the note. LockDoc
07-04-2020, 01:33 PM | #34 |
07-04-2020, 02:28 PM | #35 | |
Thanks Jeff. Doing good here in Iowa, Slowww and easy.. LockDoc
07-05-2020, 11:05 AM | #36 |
just a tip for nuts and bolt cleaning, it you are a reloader,and clean your own cases, a tumbler is a great tool to clean up the small stuff.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
