Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-28-2020, 08:12 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
WTB Rear portion of a 2-Piece Driveshaft
WTB Rear portion of a 2-Piece Driveshaft that has the HD carrier bearing. I just need the rear driveshaft.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-28-2020, 08:46 PM   #2
1960chevypanel
Re: WTB Rear portion of a 2-Piece Driveshaft
What length?
1960chevypanel is online now   Reply With Quote
Old 05-28-2020, 09:30 PM   #3
LostMy65
LostMy65's Avatar
What length you got?
Old 05-29-2020, 02:05 AM   #4
1960chevypanel
I've got a pile of them. Can you measure between the front shaft and the rear end? And what diameter is the tube?
Old 05-29-2020, 06:44 PM   #5
LostMy65
LostMy65's Avatar
30.75 inches plus or minus.
Old 05-30-2020, 08:54 PM   #6
1960chevypanel
Closest one I have is 28.5" including the yoke. A longer yoke might do the trick.
Old 05-30-2020, 11:08 PM   #7
LostMy65
LostMy65's Avatar
Thanks for checking.
But yes, I meant to say 30.75 center of u-joint to center of u-joint.
Old 05-31-2020, 02:02 AM   #8
1960chevypanel
Well that's different. I'll have to check again, probably Mon or Tues.
Old 06-01-2020, 08:21 PM   #9
1960chevypanel
I have a couple that are 33" at the center of the u-joints.
Old 06-01-2020, 08:46 PM   #10
LostMy65
LostMy65's Avatar
Yeah, 33 is a little too long.
Thanks though.
Old 06-15-2020, 09:42 PM   #11
LostMy65
LostMy65's Avatar
anyone local?
Old 11-20-2020, 01:24 AM   #12
chev-obsession
chev-obsession's Avatar
Did you ever find one?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-20-2020, 08:30 PM   #13
LostMy65
LostMy65's Avatar
No I did not.
Old 11-20-2020, 09:46 PM   #14
chev-obsession
I believe I have the one you are looking for. I can take a measurement from center of u-joint to center of u-joint and let you know.
1965 c/10 swb
1969 c/10 lwb
Old 11-20-2020, 10:49 PM   #15
Captainfab
60-66 Nut
I'm assuming that you need the HD driveshaft and not the light duty driveshaft since that is what is in the pic you posted?
Old 11-21-2020, 03:36 AM   #16
LostMy65
LostMy65's Avatar
Yes, when I wrecked my longbed back in the 80's, I just had the rear portion of the driveline shortened.
My uncle welded something that I could bolt to the 62 x-frame donor.
My 65 is still on the 62 donor frame. I've been thinking of going back to a longbed, and to do that, I need the stock length of the rear portion of the driveline.
Old 11-27-2020, 04:59 PM   #17
chev-obsession
I measured 43.5” center to center on the U joints. Let me know if this is what you are looking for
Old 11-27-2020, 05:24 PM   #18
LostMy65
LostMy65's Avatar
Thanks, I need 30.75 inches plus or minus center of u-joint to center of u-joint.
Old 11-27-2020, 08:49 PM   #19
Clatterville trolley
Clatterville trolley's Avatar
Do you know if any 67-72 shafts would work - I have several from trucks I have parted out and would be willing to measure some to see if I have what you need. I see that the length center to center u-joint needs to be 30.75 inches, but I think I missed seeing the tube diameter.
PayPal 1windyridgeboy@gmail.com
Clatterville trolley is offline   Reply With Quote
Old 04-12-2021, 10:19 PM   #20
LostMy65
LostMy65's Avatar
Thanks,
Still looking for local.
Old 12-19-2021, 05:22 PM   #21
LostMy65
LostMy65's Avatar
Yes, I need the HD one.
