Old 05-31-2020, 12:33 PM   #1
Bridgeman57
Bridgeman57's Avatar
1986 block, 1987 heads- CAM HELP
I bough an engine with TBI and I’ve swapped it to carb. I want to put in a new camshaft but not sure what all I should replace because the cam in the block is setup for TBI. Because the degree would be off center a little. Would the stock cam be alright? And if I do add a cam, would I have to install new lifters, rods, valve springs, timing chain? Or would simply moving the cam timing a few degree be easier then spending roughly $500 more into a ****ty stock engine. Or just leave the cam alone and run it?
Suggestions and advice would be great.
Bridgeman57 is offline   Reply With Quote
Old 06-01-2020, 04:55 PM   #2
THI
Active Member
THI's Avatar
Re: 1986 block, 1987 heads- CAM HELP
The stock TBI cam is really small - around 179* intake duration @ .050" lift. The old 193* intake/202* exhaust cam used in the 307-400 small blocks is a big improvement and would work with the valve springs. The TBI heads are poor flowing heads so going too big on a cam would not work well. Many have had good luck with an RV cam (204*/214*)
THI is offline   Reply With Quote
Old 06-10-2020, 08:49 PM   #3
MikeB
MikeB's Avatar
No reason the TBI cam won't work with a carb. But as mentioned above, it's quite small with an emphasis on low RPM torque. Something like a Summit Racing SUM-K1101 cam & kit would be an improvement, without killing low RPM performance.
https://www.summitracing.com/parts/sum-k1101
Be sure to read everything you can on breaking in a flat tappet cam!
As moderate as it is, a 204/214 cam would be a bit big in a 305 with tall gears, like 2.56 or 2.73.
Edit: Yes, if you install a new cam, you must use new lifters and probably will need a new timing set.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
