08-05-2023, 08:14 AM | #1 |
Mr. Cheyenne
Love When Parts Fall Off - Rubber Mounting/Body Supports
The other day I found this rubber bit on the floor of my garage (photo 1). I am pretty sure this is the passenger side lower radiator rubber mounting cushion. Photo 2 is the cab's driver side forward lower rubber mounting cushion and then Photo 3 is the cab's backside lower rubber mounting cushion.
My brain says if you need to replace one, replace them all. Yes? I'll go with rubber, not polyurethane and I think I'll source the parts from GMC Pauls. I viewed a YouTube from LMC Tucks and seems straight forward for the cab with a helper. Question: But when you do one side and jack up the cab - that won't put stress / bend anything on the other side if it isn't loosened? For the lower radiator, LMC Truck's YouTube isn't for a 72, seems there was a change - the LMC Truck's video is for 60~68. Question: Anyone have a steps/tips - how much disassembly is needed to get the old ones off and the new ones in? Overall it seems the hardware is in pretty good shape all around, though I think I'll get the full kit from GMC Pauls. Which you can get the bed bits too. They sell "Bed Mounting Pads", is this a upgrade? Suggestions on this item?
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 08-05-2023 at 08:28 AM. |
08-05-2023, 09:41 AM | #2 | |
The Older Generation
Re: Love When Parts Fall Off - Rubber Mounting/Body Supports
The back one is in pretty good shape. Replace them all. Be sure you get the kit for your application. 1/2 and 3/4 tons are different. Looks like yours is a 1/2 ton. Basically you only have to raise the cab enough to slide the upper bushings in and there should be enough give in the mounts for that. I do side to side to replace them, instead of front to back but you can do it either way. Don't go any higher than you need to to get the top bushings in. You may or may not need the metal shims. The rear bolts come out the from the bottom and the front ones come out from the top. The front ones may have a spot weld on the head of the bolt, if so you will have to cut or grind the spot weld off to get the bolt out. The rear bolts have a cage nut on the inside of the cab so they should just unscrew from the bottom. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-05-2023 at 09:47 AM. |
08-05-2023, 10:03 AM | #3 | |
Mr. Cheyenne
Hey Leon,
Thank you for that information. I had sent in a question to GMC Paul's, didn't expect a Saturday reply. I do in fact have a C10 1/2 Ton Truck, I believe I'll get the full kit and use what I need from it. I think I'll also get the optional "Rubber Bed Mounting Pads". My brother has offered to help in his shop, just need to find the time to drive up to East Texas. If anyone has tips for the front/radiator (pictures?) of what it take to do those two - that would be great! Quote:
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
08-05-2023, 10:25 AM | #4 | |
The radiator mounts are basically the same as the cab ones. They have a carriage type bolt in them but they have a keeper under the head of the bolt that keeps it from turning while you remove the nut. You may have to have a helper hold down on the head of the bolt while you remove the nut. Sometimes when you get them loosened up a little bit they will want to start turning. Spray the threads & nut underneath with penetrating oil before you start. I can't remember off the top of my head if the radiator needs to be raised up to get the bolts out or not. LockDoc
08-05-2023, 10:31 AM | #5 |
Mr. Cheyenne
Sorry if this is a stupid question...
Should you do the Cab first and then Radiator or doesn't matter? Just wondering if I could try to tackle the Radiator first one each one at a time? Seeing that one of them mostly fell off the truck!
08-05-2023, 04:22 PM | #6 | |
Go to the other side and remove those nuts and bolts. Place the jack and 4X4 as you did on the previous side and raise the body a couple inches.. Replace the remaining mounts.. Remove the jack and tighten bolts to the recommended torque. Replacing the mounts side to side instead of front to back maintains the fender/door alignment and nothing gets "buckled" in the process.. |
08-06-2023, 01:40 PM | #7 |
Mr. Cheyenne
Thanks Rusty!
Why can't I find the radiator support mounts in either the Service, Overhaul, or assembly manuals? I can find the Cab's support mounts all over the place... I must be blind I guess. I assume the torque is the same between the radiator and front cab support mount nuts - 40~55 LBS FT? Interesting there is a difference in the LBS FT between front and rear support mounts on the cab.
08-06-2023, 05:12 PM | #8 | |
This is exactly how I did mine. While there, shimmed the cab to be level/even with the bed. The body lines were off by 3/4 inch on driver side and 1/2 inch on the drinker side. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-06-2023, 08:09 PM | #9 |
Me too.
Also, the front cab ones are much easier if you have a buddy. And if you are under the truck wear goggles, lol, cause 50 years of dirty is going to fall out and on your face.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-19-2023, 12:58 PM | #10 | |
35-55ft lbs Paul Jr @ GMCPauls |
