09-17-2023, 08:12 AM | #1 |
Speedometer correction for tires
I know this has been covered a lot, but so many links are just dead that could help me.
I have a 2wd 72 C25, SM465, 4 10 Dana 60 I am tired of the extremely wonky speedometer needle, so I wanna replace the cable (at least im told that's from the cable) Firstly, do you know what length cable I need? Secondly, I'm running 285/75R16s in the back, what gear should I have? She originally had 9.5R16.5s when I got her. Thanks!
1972 GMC C25 350 Muncie 465 - Daily Driver 1979 AMC AMX 304 4 Speed -Mechanic Special 1983 AMC Eagle - The Eternal Project |
09-17-2023, 09:45 AM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Speedometer correction for tires
Cant help with the gears, but if you take your existing speedo cable out and clean it, you'll most likely solve the wavey or twitchy speedo needle. You can pull the inner cable out of the outer sheath and soak them in a parts cleaner. Or a pan and some gasoline or a couple cans of break clean. Once clean, squirt some white lithium grease into the sheath and reassemble the inner into the outer.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-17-2023, 09:57 AM | #3 |
GMCPauls has one that is 70"
Scroll down about 5th from the bottom. Link: https://gmcpauls.com/instrument_panel.htm
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-17-2023, 10:30 AM | #4 |
Like said before start with the cable. You would be better off cleaning the old one and lubing instead of buying a Chinese cable. Speedo is corrected by the cable drive gears in the trans or a gear reducer on the trans. You should be able to find info how to calculate and what color gear you need
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
09-17-2023, 11:24 AM | #5 |
Here's a Speedometer gear calculator you can use. It says your tire diameter is 32.83. Plug that in, along with 4.10 for your rear end. You will have to determine the number of teeth on your currently installed drive gear so you can enter that, too. Then it will calculate the number of teeth you need to get for the driven gear.
https://www.tciauto.com/speedometer-gear-calculator |
09-17-2023, 05:06 PM | #6 |
Awesome! Thanks!
The drive teeth would be the one on the transmission side?
09-17-2023, 05:17 PM | #7 |
Yes. The drive gear is mounted inside the transmission on the main output shaft going to your driveshaft.
09-19-2023, 03:20 PM | #8 |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
09-19-2023, 05:53 PM | #9 | |
Can you buy just that piece and crimp it on?
