09-19-2023, 02:05 AM | #1 |
60-66 clutch pedal compatability?
I've been searching online, and can't find comparable part numbers that will verify.
Anyone with OE parts lists, or better yet prior experience that would answer this? Will the clutch pedal from a 1960-66 fit and function in the pedal assembly in a 1967-72? I've found drawing that make them appear similar, but I'm not finding part numbers that match them up. I'm actually converting mine over to Hydraulic, but I need the clutch pedal and through shaft to mount up properly in the brake swivel tube. Thanks!
1971 C10 SWB 350/350 A/C PS PDB |
09-19-2023, 06:44 AM | #2 |
Re: 60-66 clutch pedal compatability?
I would assume the 64-66 will . 63 and older had different frames so I doubt they are compatible.
09-19-2023, 08:30 AM | #3 |
09-19-2023, 05:40 PM | #4 |
Based on the parts catalog, it appears that the part number for the clutch pedal is different for 65-66 vs. 67-72. One apparent difference based on the drawing in the catalog is that the little arm that attaches to the right end of the shaft appears to be at a different angle.
Pedal, Clutch 65-66 3820085 67-72 3889910 |
