Steering is strange
So, I did a full rebuild on the front of my 68. New tires, wheels, drums, brakes, wheel cylinders, brake lines, master cylinder, steering box (manual) all the steering linkage, ball joints, springs, a-arm bushings, shocks etc.
dropped the front by 1" and changed to 255/60/17 tires. Had an alignment done. Steering is strange now. Tracks straight and all, but when turning the wheel fully it acts like the truck is going to push itself over the tires (if that's an odd description...sorry) It's like the truck doesn't want to do a tight turn...even in the driveway...the wheels will turn fully...it's just that beyond say 60% of a full turn to either side it feels like I've got skids instead of tires... there's no rubbing going on anywhere that I can find. What to try ? |
Re: Steering is strange
Sounds like your tie rods are on backwards post a few pictures
If they are they could be hitting on the cross member
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
![]() Join Date: Apr 2010
Looks like your inner tie rods are in front of the center link and should be on the back side of it.
![]() Join Date: Dec 2012
agree..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Yep, the inner tie rods are mounted backwards...I must have been very tired and very blind...
I'll fix that...double check part numbers to make sure the inners are inners and the outers are outers... and realign and report back Thanks Everyone !!! |
You'd think the alignment shop would have caught that.
The Older Generation
I would think that would mean that the center link is on backwards too. Unless I'm not thinking straight here.... LockDoc
Turned everything around and aligned by sight ( till I go back to the shop ) and the feeling of skidding instead of steering is gone...
Thanks Everyone !! |
#12 | |
Good deal! Pretty easy fix considering all things that can go wrong.... ![]() LockDoc
#13 |
![]() Join Date: Jun 2022
fixing this would move the inside end of the tierods further back and toe in the tires by some amount, no?
#14 |
I thought the inner tie rod ends should have the zerk fittings on the ends, not facing the cross member. The inners look wrong to me....No way to put grease in these?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#15 |
You have to turn the wheels at full lock the center link comes away from the crossmember he could alway put the zerks like your control arm bushings .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-19-2023 at 08:24 PM. |
