6.0L Problems.
So I have a 2003 GMC 2500HD with the 6.0L. This thing has been a damn lemon from the time I got it. Started out with an intermittent no crank, which I had to fix cause I needed the truck, it was the ignition switch / wiring. The not so major issues I am having off and on currently are intermittent service brake light, and intermittent service 4wd light. Of course neither of those will stay on or come back when I have time to try and scan it or stop at a shop...
Now the serious stuff... Had a check engine light come on about 2 months ago, scanned it and I need knock sensors, well work was busy so couldn't do it, couple weeks later it starts running HORRIBLE! Sounds like a lumpy cam on idle, stalls out in the cold etc. Scanned again, has like 8 codes... Knock sensors, couple misfires, lean condition both sides, Maf or Map? Sensor, O2 sensors.. Whatever, it was eating fuel had no power and ran ****ty, but being my tow machine I had to drive an hour on the highway so I rocked it anyways, got back to the City stop and throw gas in it, start it back up, no oil pressure! Of course me being me I said **** you truck and drove it home anyways (20 min drive) it made it so I left it on the driveway for 2-3 weeks... Had to pick something up so i fired er up again, has good oil pressure, so I drove it for that week, parked it again for a week. Start it up today has good oil pressure drive around, stop for gas again, no oil pressure again! Me being me again I drove the ***** home haha (20 min) Where should I start? I think my plan is compression test it, if thats good, mech oil pressure test. (where can I hook up?) good or bad I will go from there.. I don't want to throw money at this thing if the motor is ****ed I'd rather swap a Cummins or D-max in it. (Before we all say no, I'm an ex Diesel Performance Tech) Just not sure about this damn 6.0L if its worth fixing or what.... *Drinks a beer or 3*
2003 GMC 2500HD 6.0L 4x4 SLE 1998 Chevrolet S-10 ZQ8 4.3L Step Side 1994 Chevrolet S-10 4x4 Step Side 5.7L Vortec 5 Speed SAS 1982 GMC C1500 350 700r4 5/7 Drop 1951 Chevrolet 3100 S-10 Frame 383 TH400 |
Re: 6.0L Problems.
oil guage does not mean you dont have oil pressure... those dash clusters are soo finicky and they always give odd readings.
if you had no oil pressure your drive train would be screeming lifters clacking rockers clanking reset the codes after you write down all the codes... take it for a spin until codes set... 1st code set is first problem you address.... solve that others may go away or then you can eliminate one of many problems.. its just logical troubleshooting
Ed will be known as the Tiger Woods of the integration business |
Re: 6.0L Problems.
Its probably intake gaskets and the knock sensors in the valley are corroded ( if its the same kind in the wells between the heads), combination of these two very common problems with these motors can do all sorts of wacky things. If you're going to toss it, toss it on a truck to California for me :P
#4 | |
Re: 6.0L Problems.
My old S-10 lost oil pressure on the highway when I had it and I said ff it and drove it home still, never made a sound until it seized up dead a block from my house haha! Was expecting the same with the 6.0L but shes still goin! I have never had this much trouble with a GM engine before, which is why I think it might be something major.... Hopefully not, if Compression is good and Oil Pressure is good, knock sensors will be changed to start. If oil pressure is no good I'll change the pump, if it's still bad then obviously the bearings are toast and the motor is out! Still need to know where can I hook a mech oil gauge? I know the Cummins, D-max and Powerstrokes like the back of my hand but gassers aren't my thing, the price was right on this one but apparently there was a reason for that......
