View Poll Results: which paint job looks best? | |||
1 | 0 | 0% | |
2 | 0 | 0% | |
3 | 1 | 5.88% | |
4 | 0 | 0% | |
5 | 0 | 0% | |
6 | 0 | 0% | |
7 | 6 | 35.29% | |
8 | 2 | 11.76% | |
9 | 4 | 23.53% | |
10 | 1 | 5.88% | |
11 | 1 | 5.88% | |
12 | 4 | 23.53% | |
Multiple Choice Poll. Voters: 17. You may not vote on this poll |
06-11-2013, 11:58 AM | #76 |
Re: 71' (gonna be) a one of a kind custom
No real big updates, but I did manage to score these beauties
Posted via Mobile Device Even if I can't register them to the truck it will just be nice to have them. Does anyone know if you can register with plates like this? Posted via Mobile Device
..........___ ..____//_{)] ______ [_(O)_[___][__(O)_] Project: Under Pressure II http://www.67-72chevytrucks.com/vboa...d.php?t=559720 |
06-14-2013, 05:06 PM | #77 |
I ordered my rack & pinion kit from No Limit just now, and a big thank you to Tina over there at No Limit. She was a huge help! Should have install pics by next weekend!
06-14-2013, 10:30 PM | #78 |
Can't wait to see it installed ! What pump setup are you going to use ?
84 step side 87 swb |
06-17-2013, 10:12 AM | #79 |
I will be running the Edelbrock serpentine set up that comes with it's own p/s pump. I am sure there will be some custom hoses I will have to have made for it.
The other problem is going to be that all these parts are polished and I do not want anything "chrome" on this truck. So, I will have to figure out what I am going to do about that......
06-17-2013, 04:12 PM | #80 |
like this, but without all that chrome
06-22-2013, 11:29 AM | #81 |
Just found out last night, the rack won't be here till' the middle of next week........... stay tuned!
06-26-2013, 08:48 AM | #82 |
My No Limit rack is on the FedEx truck for delivery this morning, planning on showing the entire install of the rack on here step by step to share my experience with the setup that will hopefully be some useful info for others future installs.
06-26-2013, 09:20 AM | #83 |
That's great, can't wait to see this install.
06-26-2013, 09:01 PM | #84 |
Got home and did the inventory check........
Then went to mock fit the bracket, and this is what I ran into............... The lower control arm u-bolts are hitting the bracket. Should I just grind the bracket, or is there something wrong?
06-26-2013, 09:46 PM | #85 |
Subscribed and droolin
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
06-26-2013, 10:22 PM | #86 |
Thats easy enough to solve just notch the bracket then add a rib to reinforce it and move on there is nothing to see here
06-27-2013, 04:50 PM | #87 |
More work on the rack comming this evening, in the meantime I have another little teaser project. Been thinking about doing a rendering of what I would like the paint job to look like. So instead of a drawing, I will be working on a more 3D rendering.
I know, it's a short bed, but I am not going to hold that against it. Besides, you try and find a model of one if the in a long bed Posted via Mobile Device
06-27-2013, 06:02 PM | #88 |
67cheby
with the quality of work they do at No Limit I doubt if it is meant for you to have to notch it , I would give them a call and see what they say !
06-27-2013, 06:10 PM | #89 |
I agree, but the u-bolts I am using here are from LMC and much bigger than the factory ones were. I believe that is most likely the issue. I did send Rob a message too though.
06-27-2013, 07:42 PM | #90 |
It wont hurt it to notch it though, don't let it hold you up.
06-27-2013, 10:46 PM | #91 |
Went ahead and notched it, didn't take to much to clear.......
....... Then fitted the rack itself....... going to nee to do some grinding on the cradle, that will have to wait for tomorrow though. I am loosing the light and my swimming pool is calling my name!
06-28-2013, 12:10 PM | #92 |
67cheby
well that would make sense then !
06-28-2013, 12:47 PM | #93 |
Looks like a nice setup.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-28-2013, 01:08 PM | #94 |
Sweet setup! I've been curious about the no limit rack. Aside from your CPP u-bolts, are there any issues with bolting this thing up?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-29-2013, 10:45 AM | #95 |
Got the grinding of the cradle done........
....... Then did some touch-up......... ........ And started on giving the rack a new paint job........
06-29-2013, 01:22 PM | #96 |
Mounted the bracket.......
........ painted the other brackets........... ........ finished painting the rack............. ......... went ahead and painted the spindles............ ......... decided not to use my trailing arms, waste of powder coating and new bushings........
06-29-2013, 02:43 PM | #97 |
That's ok you can easily sell those trailing arms and recoup what you spent to refurbish them plus some.
06-29-2013, 03:13 PM | #98 |
motor exploder
What trailing arms are you going with? (or are you holding out to surprise us with something else?)
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-29-2013, 09:53 PM | #99 |
Notched the frame for the u-joint......
........then did the test fit.......... ........needed to clean up the frame a bit, so took it outside......... .........however much you think you need to notch the frame, you can bet on just about doubling it..............
07-01-2013, 01:14 PM | #100 |
So I installed the steering shaft bearing, not too hard to do. Just remember, you do have to shave the outside edge of the bearing collar so it fits the inside of the frame rail.........
Now the u-joints provided come with two set screws, one long and one short at each collar. I found it best to use two of the short ones on the side closest to the rack (for clearance issues) and the longer two in the middle as you see here........ I missed something when I was doing my inventory check, missing washers for the outer tie rods. No big deal though, I will just pick some up this evening...... Other than that, she's all done!!!! Final thoughts for this install: Remember, this is NOT a bolt up kit. There is a lot of cutting, grinding, and drilling involved. I know most of the guys on here are comfortable with that, as for my self, going in I was apprehensive about doing all of this. It was l lot of hard work, but now that it is done, I do not regret the decision to go with the No Limit kit.
