11-29-2015, 08:57 AM | #76 |
Re: 1972 c10 om 2001 tahoe 4x4 chassis
11-29-2015, 05:14 PM | #77 |
Ok the cab is back on for the final time. Now just test fitting the rest of the body then time to make it run
11-29-2015, 07:06 PM | #78 |
All about them K’s
Are you posting this all real time?? I.e. As its happening? If so this is pretty incredible that you've got it to this point in only a week or two. Looks like your doing excellent work. I've done a K/5 frame swap on my 3100 so I know first hand the amount of work this takes. Looks like your doing a great job!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-29-2015, 08:58 PM | #79 | |
12-04-2015, 11:09 PM | #80 |
i built the new steering shaft and installed the 2008 trailblazer ss brake booster and master cylinder
01-13-2016, 08:26 AM | #81 |
Any updates on this? I was enjoying this one.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-14-2016, 01:10 AM | #82 |
Yes, more please! I'm doing a similar swap but with a 2011 GMC Savana AWD van. I'm only using the chassis/running gear but have some questions for you. Looks like the track width of the van and Tahoe are fairly close, I believe the van is a few inches wider, have you run into any issues with wheels protruding from the fenders? Looks like your keeping the stock height, mine will be as low as possible so I'm anticipating fitment issues. Why did you redo your gas lines? I'm enjoying your build, keep the updates coming.
Ben |
01-14-2016, 01:12 AM | #83 |
Oh and what did you use for the steering shaft. Thank you
01-14-2016, 05:20 AM | #84 |
Subscribed I'd like to do one with a awd escalade
01-14-2016, 12:26 PM | #85 |
This looks awesome. Does anyone have links to other body swap build threads like this?
1968 Chevy C20 |
02-07-2016, 03:44 PM | #86 |
ok getting back on track. i had to work for a couple months now i have about a week of down time. i need to re do the brakes then mount the rest of the sheet metal. after that it will be time to test drive
02-07-2016, 03:46 PM | #87 |
new carpet also came in
02-07-2016, 03:47 PM | #88 |
02-07-2016, 03:49 PM | #89 | |
03-07-2016, 04:20 PM | #90 |
You are doing an awesome job. Do you still have the crew cab short bed with the 6.5 TD?
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
03-07-2016, 05:41 PM | #91 |
subscribed
03-07-2016, 06:29 PM | #92 |
Subscribed
03-07-2016, 09:30 PM | #93 |
You sir are doing some nice work !
72 C20 Longbed 05 1500 Z71 |
03-15-2016, 06:22 PM | #94 |
Rebuilding the front end. I want it to drive like new
03-15-2016, 07:19 PM | #95 |
03-16-2016, 06:50 AM | #96 |
Can you give me some info on it or pictures? I am currently building a 88 crew cab short bed that I converter to 4x4 and I have a 6.5TD/NV4500 for it. I haven't seen or couldn't really find anyone who has done a build thread on it.
03-16-2016, 11:33 AM | #97 |
Looks great so far.
1969 Chevy c20(Miss Hackjob) |
03-16-2016, 12:48 PM | #98 |
looking GOOD sir...
03-16-2016, 12:54 PM | #99 |
Great job so far man, looking forward to seeing it on the road!
03-16-2016, 09:47 PM | #100 |
Knuckle Buster, Instructor
Crew cab shortbed with a 6.5? I'm intrigued, especially one that's for sale. Tell us more!
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
