11-22-2019, 10:31 AM | #1 |
New dip stick
Anybody know where I can get a stock Chevy dip stick for a 350?
All I have found in the local parts houses are "close" to being right or cut to fit. TIA, Kevin D |
11-22-2019, 10:34 AM | #2 |
Re: New dip stick
Does it have a driver's side dip stick or passenger side one? I got a driver's side one from the local chevy dealer, which fit way better than anything I have seen aftermarket.
11-22-2019, 11:03 AM | #3 |
Re: New dip stick
Drivers side. Might have to stop by the dealer.
11-24-2019, 10:47 AM | #4 |
Re: New dip stick
I'll toss in another vote for getting it at the dealer; cheap and fits like it's supposed to.
A few Fords and a couple of Chevys |
11-25-2019, 11:00 AM | #5 |
Re: New dip stick
Do you have a part #? Dealer says it’s too old to look up
Posted via Mobile Device |
11-25-2019, 11:04 AM | #6 |
Re: New dip stick
It's 2 pieces, hope these help
Item Oil Tube (GM # 12337946) Gauge Assembly (Dip Stick GM # 3981019)
11-25-2019, 11:56 AM | #7 |
Re: New dip stick
Does year matter? Or is this pretty much a universal dip stick? I need a new one for my 77, the one that’s in there is way too loose and the entire tube pulls out when i check the oil
11-25-2019, 12:27 PM | #8 |
Re: New dip stick
For those that have the dip stick on driver's side of engine. The hole sizes are different than the ones on the passenger side. Not sure what the cutoff year was for the changeover
11-25-2019, 12:29 PM | #9 |
Re: New dip stick
11-25-2019, 01:19 PM | #10 |
Re: New dip stick
I think they moved it to the passenger side starting with 1980 models. Some blocks and oil pans, like those used on the base Goodwrench 350 crate engine, have provisions for both sides.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-25-2019, 04:10 PM | #11 |
Re: New dip stick
If you install a crate engine and use the driver-side dipstick, be sure to correctly plug the hole on the passenger side or you'll have yourself the rare "continuous oil-mist undercarriage rust inhibitor" option installed. The plastic shipping plug is not all that is required. Ask me how I know. And be sure to do this when building the engine on the stand. Before the exhaust manifolds are on.
PO install, by the way... heh.
Ryan - WANTED: '60-'66 4X4 Suburban/Carryall Meet 'Earl', '71 C10 Suburban - Sold, but not forgotten... Meet... yet to be named, ‘78 K10 Suburban Daily Driver |
11-26-2019, 07:34 AM | #12 |
Re: New dip stick
Local dealer doesn't have one in stock and says he can't order it because it is discontinued. Can anyone recommend another source?
11-26-2019, 08:06 AM | #13 |
Re: New dip stick
try ebay
11-26-2019, 10:38 AM | #14 |
Re: New dip stick
These might be worth a try. Neither one is chrome.
https://www.summitracing.com/parts/s...make/chevrolet https://www.summitracing.com/parts/m...et?prefilter=1 Found this GM tube, but not a dipstick: https://www.summitracing.com/parts/n...6870/overview/
11-30-2019, 07:10 PM | #15 |
Re: New dip stick
73-79 350 older factory motor dipstick on pass side.
Try motor rebuilder shop local. just tell them what year motor and side dipstick you have Oh and if you changed your bottom end, oil pump, oil pan bigger, or deeper if not stock.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
