Old 03-14-2018, 12:08 AM   #1
Cooter0003
Carb backfire issues....I need some advice
On my 83 suburban 4x4 with a 350, I’m having light/medium throttle back firing issues, I’ve tried everything. Timing is at 12 degrees initial, 38 total I’ve got 18 inches of vacuum at idle float bowls are set right as best as I can tell, it’s a Holley 4160, I can’t figure this out it’s driving me nuts. What y’alls opinion??
Cooter0003 is offline   Reply With Quote
Old 03-14-2018, 09:27 AM   #2
geezer#99
geezer#99's Avatar
Re: Carb backfire issues....I need some advice
Could be the dreaded ‘flat cam’!
Pull one valve cover at a time and check all the rockers are moving the same.
Old 03-14-2018, 11:29 AM   #3
Cooter0003
I will on Friday when I can get new gaskets, the previous owner of this truck rtv’d the hell outta the gasket, but I put a buddies Edelbrock carb on it this morning, and so far no popping or backfires at all. It may have a bad cam the last owner wasn’t very kind to this truck at all
Old 03-14-2018, 12:17 PM   #4
geezer#99
geezer#99's Avatar
Drive it awhile before you pull the covers.
Might be a power valve or something plugged up in your Holley. Or a vacuum leak. Or the po did some mods to the Holley.
Old 03-14-2018, 01:58 PM   #5
Cooter0003
I think it is a cam, it popped once with the Edelbrock
Old 03-17-2018, 12:40 PM   #6
andyh1956
Pull your plugs & check the color. You COULD have a part throttle vacuum leak.
andyh1956 is offline   Reply With Quote
Old 03-17-2018, 09:02 PM   #7
amberkalvin
amberkalvin's Avatar
I assume it's only popping back through the carb when it happens? I had something similar happen mainly out the exhaust pipe, checked cam and rockers, timing etc. Turned out to be fouled plugs. Sometimes it's the little things.
1984 SWB C10 (http://67-72chevytrucks.com/vboard/s...d.php?t=687521)
1976 K5 super rusty fitech truck(http://67-72chevytrucks.com/vboard/s...d.php?t=740582)
The one I'm keeping forever (Fingers crossed!)
1989 Suburban 2500 L83 6L80
(https://67-72chevytrucks.com/vboard/...d.php?t=818822)
amberkalvin is offline   Reply With Quote
Old 03-18-2018, 01:01 PM   #8
Cooter0003
Yea it only pops through the carb, and it has new accel plugs in it, and the color on them is light tan on the porcelain. Could a stretched timing chain cause the problem?
