Old 12-29-2019, 10:02 PM   #926
boonedogs72
boonedogs72's Avatar
Re: What did you do to your Blazer/Jimmy today?
Got my OG paint polished the rest of the way out yesterday and got the old original 307 fired off after setting in a barn for 20 plus years!
boonedogs72 is offline   Reply With Quote
Old 01-02-2020, 04:42 PM   #927
raggedjim
raggedjim's Avatar
Looks great, good job!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-02-2020, 05:55 PM   #928
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks nice, more pics please.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-02-2020, 07:48 PM   #929
Chulisohombre
Chulisohombre's Avatar
Looks great. Just need some tires that fill the wheel wells.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 01-03-2020, 10:16 AM   #930
Austinjay
Austinjay's Avatar
Got the interior and patch panel paint finished. now its reassembly time with all new interior. I also ordered a "original looking" bluetooth radio from custom autosounds and the new push on door seals from GMC pauls.
'72 K20 Ochre/white 350/350/205 4" Lift 35's
'72 GMC K10 red orange/white 400/350/205
'69 C20 Longhorn 454 TH400
'72 Blazer CST 4x4
'70 Blazer 4X4
Austinjay is offline   Reply With Quote
Old 01-03-2020, 11:37 AM   #931
Spf79
Spf79's Avatar
Looks great!!!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 01-03-2020, 08:48 PM   #932
Gillnetter
Gillnetter's Avatar
Is that a factory color?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 01-04-2020, 12:35 PM   #933
boonedogs72
Thanks guys, have a set of 33’s with cucv Steelies waiting Togo under it. Got it fired off and drove it for the first time New Year’s Day! Have a short video on my Instagram Boonedogs32.
Old 01-04-2020, 09:35 PM   #934
Ptjsk
Preparing the rear passenger area for carpet.
Dynamat down, what about the wheel wells and the inside of the bed walls?
Also, you can go to my build thread to look at additional pictures.
Thanks,
Pat
Ptjsk is offline   Reply With Quote
Old 01-05-2020, 11:45 PM   #935
Ptjsk
Now the bed sides lined also. Then added 1.5" solid foam insulation over that.
Hopefully, this will make it sound a bit better in the cab.
Pat
Old 01-06-2020, 05:21 AM   #936
mcmlxix
Collector of Projects
mcmlxix's Avatar
On my resto-mod K5, I built the front half of a rear body harness. I used GLX wire and Deutsch connectors. I also added a couple wires to have my LED rear side marker lights act as rear turn signal lights as well. All covered in F6 split braided loom that was run along the body rather than inside the frame.
I still need to build the rest of the harness on the truck to connect to the actual lights and tie into a trailer wiring lead....
Rich
1972 K5 Blazer CST Click HERE
Old 01-06-2020, 12:03 PM   #937
Austinjay
Austinjay's Avatar
yes its 512 dark green poly
'72 Blazer CST 4x4
'70 Blazer 4X4
Old 01-06-2020, 04:24 PM   #938
Gillnetter
Gillnetter's Avatar
Looks great! 1970 color?
Old 01-09-2020, 12:46 AM   #939
boonedogs72
Still have to get my other two wheels powder coated and mounted but couldn’t wait so....
Old 01-09-2020, 05:57 AM   #940
mcmlxix
mcmlxix's Avatar
Installed the custom rear body harness.
Terminated at a junction box so I can tie into the rear trailer harness (blue wire.)
I also have LED lights on all corners and will have my rear side markers flash with the turn signals.
I also ran the harness along the body from the firewall, along the rocker box, then up through the driver side wheel well. I still need to add some clips to secure the harness along the rocker box. It's wrapped in TechFLex F6 split loom.
The only thing running inside the frame will be fuel and brake hard lines...
Rich
Old 01-10-2020, 07:02 AM   #941
mcmlxix
mcmlxix's Avatar
I had my door panels sitting on a shelf for years...
I decided to take them down, wash them and hang them on the doors with a couple bolts. They were covered in Line-X and I had the trim powder coated in red. Still need some arm rests... trying to decide on Black or try Red....
I still need to install my NuRelic power window regulators as well...
Then figure out what to do with the hole where the window crank used to be... Maybe a cup holder...
Rich
Old 01-10-2020, 06:06 PM   #942
Dchamber
Dchamber's Avatar
I got the rear seat out of the donor 2001 Tahoe mocked up and made sure the passenger side would fold down correctly. Turned out pretty nice and will be a lot easier for the kids to get in and out.
1967 Chevy c20
1969 Chevy K20
1972 Chevy K5, LS Swap
1972 Chevy C10
1985 Jeep Cherokee SBC, sm465, np205 with 1 tons
2012 Jeep JK
Dchamber is offline   Reply With Quote
Old 01-10-2020, 08:50 PM   #943
3757chevy
3757chevy's Avatar
That's cool.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-19-2020, 09:16 PM   #944
boonedogs72
New NOS caps for the blazer!
Old 01-19-2020, 09:36 PM   #945
mcmlxix
mcmlxix's Avatar
Designed and installed a bracket for my Dakota Digital gauge module and OBDII interface. Cut out of stainless steel on a waterjet. Bolts to the bake pedal/steering column mount.
Rich
Old 01-19-2020, 11:15 PM   #946
3757chevy
3757chevy's Avatar
Looks good .
MIKE
Old 01-20-2020, 12:07 AM   #947
boonedogs72
Originally Posted by 3757chevy View Post
Looks good .
Even better when the picture isn’t sideways! Thanks!!!
Old 01-30-2020, 12:58 PM   #948
72 Jimmy Power
Took it out of the garage.
72 Jimmy Power is offline   Reply With Quote
Old 01-30-2020, 02:29 PM   #949
3757chevy
3757chevy's Avatar
Glad I could help.
MIKE
Old 01-31-2020, 02:13 AM   #950
Ptjsk
Nice!! That sure looks awfully clean!
Pat
