01-21-2021, 08:10 AM | #1 |
LS Swap Harness AC Wiring pin out Help
I purchased an after market standalone harness and noticed it does not come with the AC request wire. While I have the harness out does anyone know what wire or wires/pin numbers I need to add. My plans are to add a Vintage air AC/Heat set up to my 67' C10. My donor motor is an LQ9 6.0 4l80E out of a 2005 Silverado with a Delphi Green/Blue PCM
01-21-2021, 10:18 AM | #2 |
Re: LS Swap Harness AC Wiring pin out Help
You likely won't be able to do what you are thinking. Starting in 2003 trucks went to a serial data A/C request rather than a 12v one. Just run the VA stand alone and it will be fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-21-2021, 10:27 AM | #3 | |
chevy truck fan
good luck!! |
