07-01-2020, 01:23 PM | #1 |
Hydraulic Clutch to MC Connections
OK, on to the next phase of my truck. I am connecting the clutch MC to the throwout bearing. The routing of the AN line is tight, but I have 2 scenarios that would work.
1. Have the clutch line go up with a sweeping curve and down to the throwout bearing. (picture 1) 2. Use a 90 degree banjo fitting and route the cable under the truck. (Pictures 2&3) I like the aesthetics of the banjo bolt, but I have never used one before. Any drawback? Any drawback of the up and over method in the first picture? If it were you which would you choose or go a different route...explain. Keep in mind I know nothing about building a truck. I learn something when I have to do it on my truck...so far it has been good, but I don't want to screw up my T56 magnum transmission...so I come to the experts. Thanks in advance. Last edited by roll_the_dice; 07-01-2020 at 01:38 PM. |
07-01-2020, 01:31 PM | #2 |
Re: Hydraulic Clutch to MC Connections
I could be wrong as I have not dealt with something like this, but I would think that the up and over idea could cause air to get trapped in the line if it's higher than the clutch master. I like the looks of the banjo bolt better, I just don't know how it would perform
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-01-2020, 01:39 PM | #3 |
The down and under is better..and its correct ,you could get air trapped by looping it up...I've got a banjo fitting on mine ....no issues..
07-01-2020, 02:37 PM | #4 |
Thanks guys...that is why I asked. I thought about air, but thought once bled it might not be a problem. I do like the banjo bolt better. I just went out and installed it. Looks good. Going to bleed it soon along with my brakes.
07-03-2020, 12:29 PM | #5 |
I did up and over, and once bled, air is not a problem....however, I really like your banjo trick and at some point I am going to convert to that!
292 + TKO500 |
07-03-2020, 12:31 PM | #6 |
oh yeah, and I like your color!
292 + TKO500 |
07-03-2020, 02:34 PM | #7 | |
Thanks, that was the original color of my truck...is yours 503 also? |
07-04-2020, 07:39 PM | #8 | |
"sea foam green" so I went with it. Now I'm seeing it more and more.
292 + TKO500 |
