Old 10-02-2013, 08:28 PM   #1
B85
B85's Avatar
Building a 1985 Jimmy Ultra.
So what is with the Ultra,you ask. It is the motorout of a Buick Ultra ,a Supercharged 3800. It will be replacing a 3.4 crate motor that replaced a 2.8 ,soap maker.
Was going to do a 1948 - 1954 Chevy pickup but the wife said,why not do the Jimmy up? She liked this truck and it will be her daily driver.
So on with the show. Out with the old.
And out with the new/old.
Randy
M29c Weasel
M151
S10
JK4 Door
F250 4x4
B85 is offline   Reply With Quote
Old 10-02-2013, 08:42 PM   #2
russgt
russgt's Avatar
Re: Building a 1985 Jimmy Ultra.
I've always wanted to put one of those in an S10. Neat project and I'll be watching the build!
68 stepside
76 blazer
86 Silverado
07 Sierra Z71
17 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-02-2013, 09:13 PM   #3
B85
B85's Avatar
I will reuse the tran's because it FITS! And it's paid for.
Well with some work on the converter. But will it go into the Jimmy's motor room? Well close. Will need to move the A/C pump can't get to the motor mount.
Need some new motor mounts. Oil pan mod and what about the starter?
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-02-2013, 09:23 PM   #4
B85
B85's Avatar
Then we have the intake? Will need to swing it around about 180 Deg's?
Ok thats not hard? Still working on that!
So,if it get's in it needs to get out? I will reuse some of the stock system and some from a earlyer car with the S/C. Still need the other part.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-02-2013, 09:27 PM   #5
B85
B85's Avatar
And what happend to the A/C stuff?
Needed to add a idler pulley and build the bracket for the A/C pump.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-03-2013, 08:59 AM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Cool swap. How much power does the supercharged 3.8 make?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-03-2013, 09:45 AM   #7
B85
B85's Avatar
With alittle work I should be at 300HP, 300Tq. Best thing will be off the gas we are looking for 24 MPG? But that maybe wishing.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-03-2013, 10:29 AM   #8
Bert W
Bert W's Avatar
Great idea! Subscribed
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 10-03-2013, 10:29 AM   #9
68Timber
68Timber's Avatar
We had an Impala a few years back with the NA 3.8 - great power and great mpg's. 24 mpg might not be unrealistic, hard to predict how the weight and aerodynamics will affect it but it'll be cool to see.
John
74 Honda Z50 build
Old 10-07-2013, 10:24 AM   #10
Low Elco
Well, you ain't skeered! Looks pretty cool, I've have several, great motor! Wonder how that '85 2.8 700r4 is gonna hold up? Are you having it upgraded and beefed?
Low Elco is offline   Reply With Quote
Old 10-07-2013, 07:07 PM   #11
B85
B85's Avatar
Going to leave it stock for now. I have been told that my 700r case can be built for big HP. Something about the V8 basket and more clutch plates/-+?
What about going from 2 1/4" out of the headers (cut down stock) to a 2 1/2" merg to a 3" to 3" Cat. then 3" down to 2 1/5 muffler to 2 1/4" tailpipe?
If this sounds funny, it stuff I have on hand.
I had ordered a exhaust from a older 3800 and found (when it got here ) it was not the same exhaust pattern. My bad! Other part will be here on Wed.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-10-2013, 10:19 AM   #12
B85
B85's Avatar
Parts are here for the other side. Cut,cut,cut!
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-10-2013, 11:23 AM   #13
68Timber
68Timber's Avatar
That's cool. Will you have to fab one for both sides?
John
74 Honda Z50 build
Old 10-10-2013, 01:43 PM   #14
B85
B85's Avatar
Check the upper post. The passanger side is up their. This is for the driver's side.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-11-2013, 10:08 AM   #15
Low Elco
At least it's tube you can hack into, not a casting!
Old 10-11-2013, 08:52 PM   #16
B85
B85's Avatar
Just found that the a tube is cracked! Bummer, more welding.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-11-2013, 11:52 PM   #17
truckfan
truckfan's Avatar
Lurk lurk
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 10-15-2013, 01:14 PM   #18
B85
B85's Avatar
Went with a cross over with a welded-in merge. Now working back to the 3" cat. So we go (stock cut up header) to 2 1/4" to 2 3/8 to 2 1/2 to 3" cat to 2 1/5 " exhaust cat back.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-15-2013, 01:23 PM   #19
B85
B85's Avatar
Went with a welded in cross over.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-15-2013, 06:46 PM   #20
B85
B85's Avatar
And what is this??? Its 2 1/2" on one end and 3" on the other.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-15-2013, 07:46 PM   #21
B85
B85's Avatar
What about a fuel pump? The crate motor needed a pump (no boss on the 3.4 motor for a pump) so we mounted it on the frame. My Jimmy did not have a pump in the tank. So what about mounting ( High Pressure EFI in line pump) it on the frame,in the same place but adding High Pressure fittings?
Randy
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-16-2013, 02:18 PM   #22
B85
B85's Avatar
Some work on the exhaust pipe and cat. Thinking about using a flex from the cat to the muffler??
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-21-2013, 03:37 PM   #23
B85
B85's Avatar
More new parts!! Now back to welding.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-22-2013, 03:38 PM   #24
B85
B85's Avatar
All welded! Now on to the blower.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-23-2013, 04:01 PM   #25
B85
B85's Avatar
Cleaned up the blower. Looks good inside! Also found away to install the EGR valve.
Needed to add a port for the TB. Things are just alittle tite on the back so moved it to the side.
And you need to be able it to install it.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
