Old 02-10-2020, 10:50 AM   #151
MDPotter
MDPotter's Avatar
Re: Son's 68 c10 Short Bed
I'm glad to see the bench seat back in it, I kind of miss mine. I bet he was pumped!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 02-10-2020, 11:01 AM   #152
Camaroguy
Camaroguy's Avatar
Yeah, he was definitely pumped. Truck feels like it is going to run pretty decent. Seemed snappy. Good day for sure.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 02-10-2020, 11:03 AM   #153
MDPotter
MDPotter's Avatar
Yeah, I love my LS. I just drove it a few miles Saturday now that it's got glass in it. No bed, so it's easy to leave a couple black marks on the pavement.
Old 02-10-2020, 11:07 AM   #154
Camaroguy
Camaroguy's Avatar
Here's a video clip of his first drive. Can't hear the motor but it sounds really good in person.
https://youtu.be/cNcKnmfd6oU
Old 02-10-2020, 11:11 AM   #155
Camaroguy
Camaroguy's Avatar
That's awesome.
Old 02-11-2020, 03:25 AM   #156
cornerstone
cornerstone's Avatar
DANG MANG!! That's a might purdy blue!......I may just have to git me some of that. It will depend on how well it works with the medium blue carpet and blue houndstooth seat cover I already have. I think I'll buy a small amount and spray my floor board to make that determination. That is a toyota tundra color you say, correct?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-11-2020, 11:01 AM   #157
Camaroguy
Camaroguy's Avatar
Thank you. It's a Toyota Pickup color we had mixed into a PPG Base Coat Clear Coat. Has a lot of purple in it so I don't know how it would look with the interior color you already have. Might work though. This is the print out the Paint Store used to mix if you need it.
Old 02-11-2020, 01:20 PM   #158
SCOTI
SCOTI's Avatar
It is a good looking color
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-11-2020, 03:43 PM   #159
rodstored-72
chevy truck fan
rodstored-72's Avatar
Originally Posted by Camaroguy View Post
I was able to spend part of New Year's Day working on the truck. Finished the fan relays, and the transmission cooler lines. Today, they need to find some radiator hoses and add antifreeze and fuel and it should start.
NICE BUILD... I was wondering if you might share how you ended up connecting the fans? did you use any of the motor wires (if included) or did you just fab something up?
thanks!!
rodstored-72 is offline   Reply With Quote
Old 02-12-2020, 11:26 AM   #160
Camaroguy
Camaroguy's Avatar
Thank you.
thanks!!
I didn't use any of the ls harness wiring. I went with a dual fan relay kit from Speedway or Jegs (Can't Remember). In retrospect, I would have gone the ls/pcm route.
Old 02-12-2020, 11:29 AM   #161
Camaroguy
Camaroguy's Avatar
thanks!!
The kit has a sending unit that goes into the radiator. I think mine kicks the fans on at 185 and shuts them off at 175. Wiring it wasn't really too complicated.
Old 02-12-2020, 03:49 PM   #162
rodstored-72
chevy truck fan
camaroguy,
Thanks for the responses.I did a very similar setup on my '72 previously. On this build ('86 swb) I am "wanting" to use the LS wires if I can figure it out... LOL!!!
Old 02-12-2020, 05:41 PM   #163
Camaroguy
Camaroguy's Avatar
camaroguy,
I know MDPotter just did that on his build. His thread is titled 1968 GMC - Ol' Blue. Shoot him a message and I am sure he will tell you how he did it.
Old 02-12-2020, 10:16 PM   #164
Andyking1203
Camaroguy, is it possible to post a link to your wireing harness you used, thabks.. beautiful job on the truck!!!
Andyking1203 is offline   Reply With Quote
Old 02-13-2020, 12:55 PM   #165
Camaroguy
Camaroguy's Avatar
Thanks. I am using the factory harness for the truck. The ls harness is from http://hotwireauto.com/.
Old 02-17-2020, 12:02 PM   #166
Camaroguy
Camaroguy's Avatar
Nothing real exciting from this weekend. I did get the engine and transmission computers mounted. Went ahead and just mounted it all on the inner fender. Reason being, I don't have much room under the dash with the factory hvac system and I didn't want to run the wires under the carpet. Long story short, I am lazy. Also, I still need to tie some of the wiring down.
Old 02-26-2020, 12:43 PM   #167
Camaroguy
Camaroguy's Avatar
Interesting little problem I have been having. Every since we fired this motor, I have been trying to chase down a check engine light showing low voltage to the MAF. I have tried a couple different MAF Sensors without any success. Started trying to figure it out, and through the process of elimination, I came to the realization the MAF connector was wired incorrectly. Just got off the phone with Hotwire Auto and we went over his schematic and he confirmed the B = black wire and C = red wire are flipped.
Interestingly, we are currently doing the same motor in another truck for my nephew and his was wired incorrectly as well.
Old 02-27-2020, 10:04 AM   #168
1971Stepside
Almost Satisfied
1971Stepside's Avatar
What harness are you using?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-27-2020, 10:05 AM   #169
Camaroguy
Camaroguy's Avatar
Hotwire Auto built the harness. They are great to work with to be honest.
Old 03-02-2020, 12:23 PM   #170
Camaroguy
Camaroguy's Avatar
Didn't get a chance to work on the truck this passed weekend. I did, however, snap a picture though of both my son's truck and the ls swapped '41 Ford Pickup my brother is building with his son.
Old 03-02-2020, 02:03 PM   #171
MDPotter
MDPotter's Avatar
LS swap everything! Even if it's a Ford.
Old 03-02-2020, 07:43 PM   #172
Camaroguy
Camaroguy's Avatar
Yes sir.
Old 03-09-2020, 11:17 AM   #173
Camaroguy
Camaroguy's Avatar
We test fit the hood the other day and it was hitting the air intake. I had to cut it again and rework the shape. All good now. Also, I got the other inner fender on and my son has started stripping the paint off the bed.
Old 03-12-2020, 10:38 AM   #174
rodstored-72
chevy truck fan
Yes sir.
exactly...
Old 03-17-2020, 02:39 PM   #175
Camaroguy
Camaroguy's Avatar
So the boy has been able to work on the truck the last couple of mornings. He has been focusing on stripping the bed sides. He got one side stripped and almost has the other. For some reason, they coated this thing in bondo before they painted it last time. In some places it is ridiculously thick. This is on the driver's side rear corner. It appears to have been hit at some point but really no reason for this much filler.
Anyway, we will get it fixed.......
