04-19-2020, 03:32 PM | #1 |
Carpe manana
My speedometer is now accurate
I’ve had problems with my speedometer head since post-build mile number one. The initial one had a busted odometer. This was swapped for a nice one supplied by member Tbone1964 (Tom). Given the rear end gear change and tire diameter increase the speedometer was off. Today I was able to correct the error with the addition of a gear ratio adapter from Deluxe Speedometer and Cable Service of Denver. They created the adapter in the ratio needed for my error based on comparison readings with a GPS receiver. I’m super pleased. Good service and price. USA made Eaton parts.
https://speedometercablesusa.com/
04-19-2020, 07:28 PM | #2 |
Re: My speedometer is now accurate
Thanks DeadheadNM, I didn't know they still made these adapters. My old +10% original needs replacement.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
04-19-2020, 08:17 PM | #3 |
This is what I'm looking for on as much stuff as I can find:
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-19-2020, 08:43 PM | #4 |
Super helpful piece of the puzzle. thanks!
04-19-2020, 10:40 PM | #5 |
Thanks for sharing. I have a few vehicles I would like to correct.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
04-20-2020, 08:54 AM | #6 |
Carpe manana
Absolutely!!
I needed about a 13% bump in speed at the speedo. This box has a ratio of about 1.13. Cost $108 with shipping and I got a pen from the business too. Most of you probably are aware but these K5s had a ratio adapter as standard from GM. I had a stock 1.3 or so adapter lying around and that turned out to be exactly what I needed for my k20.
04-20-2020, 11:56 AM | #7 | |
04-20-2020, 06:11 PM | #8 | |
Carpe manana
EDIT: this chart from the parts manual lists two adapters for a 3.73 rear end and several for 3.07. The chart is for four speed manual transmission equipped trucks. There are other charts for auto and three speed manual.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 04-21-2020 at 07:11 AM. |
05-26-2020, 08:07 PM | #9 | |
05-26-2020, 09:02 PM | #10 |
Man I got like six of those things. I guess I best get them out and take a look see.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-26-2020, 09:03 PM | #11 |
05-26-2020, 09:17 PM | #12 |
Carpe manana
Let us know what shakes out.
05-27-2020, 09:28 AM | #13 |
Proprietor of Dale's Corner
This is great to hear. I'm needing one too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-22-2020, 08:07 PM | #14 |
Snapped a pics of my existing adapter:
"666F 01" "1.2020" Funny thing is my speedo seems to be a be about 20% too fast |
06-23-2020, 08:04 AM | #15 |
Need to check mine, it's 10mph slow
06-23-2020, 12:49 PM | #16 |
Great to see USA made. I had the same issue with my '74 K/20 and had a gearbox made up by the guys at Transmission Center, www.transmissioncenter.net If I recall mine was about 17% off when I took my speed measurements compared to GPS
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-23-2020, 07:51 PM | #17 |
Thanks for sharing the information! This was much needed!
06-24-2020, 07:40 AM | #18 | |
06-24-2020, 12:04 PM | #19 |
06-24-2020, 12:09 PM | #20 |
It should fit right in if it is original. The adapter just fits in between the cable and the t case to change the ratio.
06-24-2020, 02:18 PM | #21 |
02-05-2021, 04:57 PM | #22 |
Good info. Thanks!
02-07-2021, 03:37 AM | #23 |
I have the exact adapter that SeventyOne has, and my speedo is 10 miles an hour low, but gets worse the faster I go! I also have the 4 speed with the granny gear.
DeadHead, when you got your adapter did you have to tell them what size tires you were running? I looked at the website, and the picture of the chart you posted, but I couldn't see where it related to the tire size. Maybe I'll take a fresh look at it tomorrow. Thanks Pete! Chris. |
02-07-2021, 03:38 AM | #24 |
Duh, I see the tire size now. Thanks again.
02-07-2021, 10:49 AM | #25 |
Several years ago I had the same issue with my speedometer being off. 71 4x4 after a swap from manual to auto transmission. I run 31x10.50x15s on 8'' rally wheels. I noted my speedometer reading against a GPS phone app and figured the difference. Contacted www.transmissioncenter.net and gave them the information. They built me an adapter that after an easy 15 minute installation was dead on with the speedometer and the phone app GPS speed. Just attached to the side of the transmission where the speedometer cable attaches.
Think my cost then was around $65 plus shipping but I'm sure costs are higher now. Very easy to do without going in to the transmission and changing the plastic gears.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
