Old 08-25-2013, 11:12 PM   #1
'63GENIII
'63GENIII's Avatar
NP205 speedometer gear interchangeability
I just swapped out the T221 for divorced mount 205 in my '63. I have the mounting issues, driveline modifications finished as of today. I have exhaust to reroute, shifter design and speedometer to finish. I thought that the speedometer connection was going to be the easiest part but found out today that I couldn't be more wrong. I noticed early on that the steel "driven gear" that screws into the tail section of the Dodge 205 was missing and really didn't give it a second thought. Well today after I finished putting the gear lube in, I decided to look online for the driven gear thinking that GM, Dodge and Ferd all used the same one. Epic fail. It appears that the Ferd is a slip in style with a retainer bolt, I haven't seen the GM style yet and the Dodge is a screw in steel type which hasn't been made for a while and even used is tough to find. I guess I could possibly swap out the tail housing for a GM style and have better parts availability but I wanted to get some opinions and maybe even some pics of the GM ones that some of you have. Or better yet, if anyone has a Dodge style driven gear in good shape, I'd love to hear from you. Thanks for any advice you can lend. Chris
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-26-2013, 04:56 PM   #2
'63GENIII
'63GENIII's Avatar
Re: NP205 speedometer gear interchangeability
Maybe I should post on a Dodge site? Anyone have a link to a good one?
Chris
'63 k15 long step
Old 08-26-2013, 09:15 PM   #3
dieseldude4bt
Chevy is a screw in steel type also, if I understand what you are looking for.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-26-2013, 10:47 PM   #4
argonaut
argonaut's Avatar
I would have thought them to be the same as well. If I remember correctly the speedo gear in my 205s is very similar to my 221. Although I'm not familiar with the dodge units. Would the one from your 221 fit into your dodge 205? (I'm sure you've already tried that)
Pics of the dodge?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-15-2013, 01:11 AM   #5
unclefreddy
unclefreddy's Avatar
Try these guys , maybe they can help http://www.transmissioncenter.net/sp...n_______va.htm
unclefreddy is offline   Reply With Quote
