09-24-2017, 10:08 AM | #1 |
292 1 Barrel Carburetor Question
Hey Folks,
My 72 has been running great all summer here in super hot Vegas. I bought it in July. As it has gotten cooler, I've noticed I had to rev it up for a little bit to keep it from stalling out. Now that our first cold front has come through I've had to crank it for a while, and it's taking way longer to warm up and not stall out. I've read a bit and think it might be the choke held open, and I should fix it and adjust the idle up. I've tons of diesel work, some small engine and almost no automotive carb work. So, I figured I'd ask exactly what is going on in this picture (choke held open?) I've got a manual choke cable on the dash. I've got a donor 350 I'm going to put in soon, so I'm just pouring in more oil and keeping the 292 on the road so I can drive it. Thanks in advance. |
09-24-2017, 10:55 AM | #2 |
Who Changed This?
Re: 292 1 Barrel Carburetor Question
Can you verify that the choke plate moves when you pull the knob out?
09-24-2017, 11:58 AM | #3 |
The Older Generation
Are you pushing the accelerator pedal to the floor and hold it while you pull the choke knob out? That is what sets the high idle on the manual choke carbs. After it starts push the choke knob in about half way until it warms up. LockDoc
09-24-2017, 06:25 PM | #4 |
I'll try that LocDoc I hadn't heard that, is their normally something other than a zip tie linking the choke and vacuum?
09-24-2017, 06:39 PM | #5 |
WTF? Zip tie? You need to remove air cleaner to determine what your choke is doing. Two people would be best, one starting and the other watching the linkage.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-24-2017, 06:47 PM | #6 |
My '68 C/10 w/292 L6 came with a manual choke. Did later models use an automatic choke? The L6s also had a heat riser on the exhaust manifold that, thru a bi-metal coil linkage, would actuate once the engine was at operating temperature [180-195*F].
I can't be more specific, since I converted to an Offy 4-Bbl intake and Clifford headers in 1978 -- scrapping the Monojet and cast iron manifolds, so I don't remember much.
09-24-2017, 09:44 PM | #7 | |
LockDoc
11-26-2017, 08:27 PM | #8 |
The choke cable is in fact pulling the wrong direction to "close" the butterfly and the zip tie to the vaccum also holds it open. Anyone have a picture of what a functioning set up is supposed to look like?
I flipped the buttefly closed while cold and it started first turn of the key. Now what to mount the cable to to be able to open it from the cab and not get it out and do it by hand in the morning |
11-26-2017, 11:07 PM | #9 |
Not sure if this will help at all as I see several things different on your carb this is a 64 c10 292 automatic ort me know if it helps at all. Hate to hear you are giving up on the 292. This one has over 300 k miles and only needed new rings and bearings.
11-26-2017, 11:14 PM | #10 | |
I'll probably keep it around, maybe throw it back in from time to time |
11-26-2017, 11:17 PM | #11 |
Well pics didn't go will try again
11-27-2017, 12:22 AM | #12 |
Looks like I need to fashion a bracket for the choke cable to attach to for sure.
11-27-2017, 01:09 AM | #13 |
Since it's likely originally a divorced choke, why not get it working instead.
11-27-2017, 10:25 AM | #14 |
11-27-2017, 10:31 AM | #15 |
I have 3 292's out in the shed. I will run out and snap some close up pictures in a little bit. LockDoc
11-27-2017, 11:55 AM | #16 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=416118 Your carb may be different but the principle is the same. A choke stove attached to the exhaust manifold has a bimetal coil in it. As the coil heats up it opens your choke via the linkage rod. The choke pull off pot is there to pull the choke plate open enough(on start up) to allow the motor to run. You can buy most of what you need to fix yours or buy a different choke plate rod with a manual choke linkage or if you really like you can adapt an electric choke to yours. Maybe give us a couple more pics of yours on the manifold. Your choke stove might still be there. |
11-27-2017, 12:08 PM | #17 |
Here are pictures of what two of mine look like. The third one I have is missing some parts. I think both of these are earlier than your carb though. The first two pictures are the same carb and the second two pictures are the same carb..... LockDoc
11-27-2017, 12:59 PM | #18 |
photos were takien while holding a baby
11-27-2017, 01:50 PM | #19 |
Flipped the pictures.... Looks like you need all of the choke linkage. You can't post a "want to buy" unless you are a Premium member but if you see what you need on the parts board you can buy it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-27-2017 at 02:13 PM. |
11-27-2017, 02:22 PM | #20 |
Looks like you'll need a choke stove. I think it mounts where those two holes are below the carb. THen you'll need a choke linkage rod from the stove and another linkage for the choke pull off. That will work if your heat riser is operable.
Might be better to go manual choke but then you'll need the correct choke plate croos shaft for your carb along with a bracket and cable. Another option is an electric choke conversion. Look in here for all that stuff. https://quadrajetparts.com/monojet-c...c-240_257.html |
11-27-2017, 04:37 PM | #21 |
Thanks for the help fellas.
I might just reach under and flip the choke in the morning. Since I'm on a maximum budget build and getting two free 350s |
