Old 01-19-2020, 08:40 PM   #1
68longhorn
68longhorn's Avatar
700r4 Pump o rings and washers?
I am replacing the front pump seal on a 700r4. The gasket set came with washers and o rings for the pump bolts but no instructions on which order the go. I assume I slide the washer on first followed by the boring? The original bolts had rubber coated washers it appears.
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 01-24-2020, 01:20 PM   #2
Myself
Re: 700r4 Pump o rings and washers?
Are the washers copper or aluminum? If so, they go on without any o'rings. I think the o'rings were on later pumps.
Myself is offline   Reply With Quote
Old 01-25-2020, 08:13 AM   #3
Bigdav160
Bigdav160's Avatar
With a 700R4 there is only one pump hole that is drilled all the way through that has the potential for leaking. However, all the bolts got o-ring seals. Earlier transmissions like the TH30 has gaskets and not o-rings. The bolts were flat. 700R4 there is a groove in the bolt for the o-ring. Common for an aftermarket set to have both. I've seen many transmissions with both installed. Gasket against the pump and o-ring on the bolt. From the factory, the 700R4 only had the o-ring
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
