Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 11-26-2015, 08:55 PM   #1
streetrod don
Power steering
Does anyone make a power steering kit for a 73 2wd truck?
streetrod don is offline   Reply With Quote
Old 03-13-2016, 08:11 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Power steering
? you did not have PS option on your truck. ?
Your looking for newer set up for your PS set up. ?
You want chrome / alum dress up kit. ?
You want to rebuild your PS with a RE-build kit. ?
I think more info might have got a answer.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-17-2016, 08:23 PM   #3
calvin78612
calvin78612's Avatar
Re: Power steering
Who are you ? The FAQ police ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 03-17-2016, 09:40 PM   #4
Pontiac1976
Re: Power steering
I see you have no answer for him ?
Old 03-19-2016, 09:44 AM   #5
calvin78612
Re: Power steering
Tuff Stuff.
84 step side
87 swb
