Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-22-2015, 12:05 AM   #1
'68 Newtricks
'68 Newtricks's Avatar
How should I fix tail light pockets :(
I decided to buy an all aftermarket bed when I did my LWB/SWB swap. I should have kept looking for an original dammit. Most of the bed went together ok, but now I'm stuck at the tail light pockets.
They don't hold the lights straight or flush. On the driver side, it doesn't hold the light at all.
Flock!!
The passenger side blows. They are crooked and not recessed enough. As you can see, I wasn't even able to put in the driver side. I'll try to get some closer pictures. What have you guys done to get a cleaner tail light finish?
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 11-22-2015, 02:30 PM   #2
kcsa75
kcsa75's Avatar
Re: How should I fix tail light pockets :(
Can't see much from this photo. Do you have some close-ups?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-22-2015, 08:03 PM   #3
'68 Newtricks
This is the bad side. The passenger side holds the lights but all kinds of crooked
'68 C10 SWB
'85 K30 Blazer
Old 11-22-2015, 10:14 PM   #4
Foot Stomper
Foot Stomper's Avatar
I would suggest measuring any solution against cutting/welding in some originals. Not saying this is the best option, but it might be worth pondering. I don't know how hard that would be but it would ensure the lights fit correctly at least.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 11-28-2015, 02:11 AM   #5
'68 Newtricks
Yeah, was thinking about that option as well. Only problem is all the structure in there plus the tailgate hinges etc. I'm thinking about cutting out the tabs that hold the light in. I wonder what it would take to just have the back of the lights bottom out against the mounting area. If the lens ends up too deep in the opening, shim it out until it's right.
'68 C10 SWB
'85 K30 Blazer
Old 11-28-2015, 09:55 PM   #6
Foot Stomper
Can you show us some pictures of the lights and how they don't fit?
Old 11-28-2015, 10:37 PM   #7
'68 Newtricks
I'll do just that first thing tomorrow. The passenger side sits crooked. When I tried to install the driver side the reverse light wouldnt stay on the ledge and wanted to fall deeper into the hole. The brake light was funky too, can't remember why anymore. :/
'68 C10 SWB
'85 K30 Blazer
Old 11-28-2015, 11:31 PM   #8
dougf
dougf's Avatar
More pics would help. I would figure out what's not fitting and move some metal with a hammer/dolly. Make it fit :-) easier said than done, I know!
dougf is offline   Reply With Quote
Old 12-04-2015, 02:18 AM   #9
'68 Newtricks
I've never done any body work before, hoping to solve this as painless as possible.
Crooked passenger side I can shim it or bend the tabs some to get them straight. Problem though, the lights seem to barely fit in. Like one small movement either direction and they want to fall off the tabs. Also, it sure seem like they should be recessed more. It's too easy to see the back of the light, the silver part.
'68 C10 SWB
'85 K30 Blazer
Old 12-04-2015, 02:21 AM   #10
'68 Newtricks
Here's the driver side. I'm holding the light so the mounting holes line up. It's about 1/4" or so too low. So I'm thinking of drilling new holes and using some rivnuts instead of the J-nuts, or body nuts (whatever they are called)
The reverse light sits in there all kinds of wrong! That may need more work.
'68 C10 SWB
'85 K30 Blazer
Old 12-04-2015, 12:24 PM   #11
MARTINSR
MARTINSR's Avatar
Reproduction parts "Similar, can be used if nothing else is available."
The cool thing is, you can cut and move stuff. Welding right there is pretty harmless not like out in the middle of the panel or something.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 12-04-2015, 12:27 PM   #12
MARTINSR
MARTINSR's Avatar
It sounds like you are on the right track, now, I don't know that truck at all so I am just tossing this out. It is from my experience that the repro parts will often simply have components welded in wrong. Is the bracket that holes the tail light in there simply welded in wrong? If that is the case the spot welds could be drilled out, then position it where it needs to be and plug weld the part back in.
But from what it looks like doing what you are planning is much better, simply use J nuts and get-r-done.
Brian
1948 Chevy pickup
Old 12-04-2015, 12:40 PM   #13
Foot Stomper
My two cent sideline post would be that you can feel free to bend those tabs to assist the fit. I'd try to bend them just enough to still be effective at holding the back side otherwise they will just "fall in".
Use the J nuts wherever you can, they are very effective little guys.
Old 02-20-2016, 10:08 PM   #14
'68 Newtricks
Re: How should I fix tail light pockets... Fixed :)
Welded some metal the the back of the tail lights. Cut out and bent the original tabs. Little cut, grind here and there. They are now straight and "Frenched" in about 1/4".
'68 C10 SWB
'85 K30 Blazer
Old 02-20-2016, 10:09 PM   #15
'68 Newtricks
'68 C10 SWB
'85 K30 Blazer
Old 02-21-2016, 11:26 AM   #16
Foot Stomper
Well done! They look great!
Old 02-22-2016, 07:37 PM   #17
'68 Newtricks
I might do a little more work on the reverse lights, maybe. They look great in person but for some reason look funny in the pic. I'll have to stare at it more, closer, in person some time. Lol I swear its straight and matches the driver side perfect hahaha
'68 C10 SWB
'85 K30 Blazer
