08-19-2017, 05:13 PM | #1 |
Condition of these rear brakes?
This is a ground up restoration on a 71 C-10. I've never done a rear brake job, but I'll pull the rear brakes today.
Question is, from your observation, should I replace these parts? There is no visual damage, including the well of the brake drums. The rear brakes were replaced some time ago, but since then I'm guessing there's just 3-4K miles on this truck. Maybe I just answered my own question, but still interested in opinions. From my angle, just clean what I've got & maybe paint the drums. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-19-2017, 05:56 PM | #2 |
Re: Condition of these rear brakes?
On another note, anyone aware of a parts diagram for the rear brakes on these Chevy's? I see some on the web for "typical" and other vehicles. If not, I may make one myself....................just as soon as I've identified all the parts (yikes).
08-19-2017, 05:57 PM | #3 |
Looks like you have plenty of shoe material left. Inspect the cylinder for leaks. Inspect the rubber hose for cracks or other wear. If those look good I say leave them as-is for now based on the pictures.
08-19-2017, 08:04 PM | #4 |
That picture you took is better than a drawing of the brakes. What you have looks fine. I would also recommend the checks above and run em.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-21-2017, 02:15 AM | #5 |
Yeah like said if no wheel cylinders and axle seals are leaking id leave them alone everything looks almost new to me.
08-21-2017, 08:50 AM | #6 |
need a head on view of the brakes that hit the drum face . how close to the rivets or cracking .
right side pic is missing the adjuster arm push up spring . and lower hold together spring looks to be out of the hole . the one just above the adjuster. diagram = only do 1 side at a time . there a flip flop of each other .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
