Old 01-22-2024, 11:12 PM   #1
AnimalMother
Medium Olive Spray Paint
Years ago someone posted of a spray paint that closely match the Medium Olive, which may have been in a thread under the "Projects & Builds" forum but for the life of me I cannot find it. Anyone have a link to who might have OEM type colors in a spray can? I'm wanting to touch up my firewall while my engine is out, appreciate any help.
AnimalMother is offline   Reply With Quote
Old 01-22-2024, 11:28 PM   #2
jocko
jocko's Avatar
Re: Medium Olive Spray Paint
I got some in a rattle can for touch-ups on this old 71 from these guys - just gotta select year-make-truck-code 504. (obviously not a professional paint job, was just trying to get it drivable/presentable)
Old 01-23-2024, 08:16 AM   #3
I can't imagine any off the shelf paint ever matching medium olive poly. That is the hardest mix to get a consistent mix using the factory code. I see it anywhere from a silver tinted green to candy apple green. Getting a spray can mixed at an autobody supply house is your best chance of getting it close
Old 01-23-2024, 01:18 PM   #4
Casper42
Casper42's Avatar
https://www.automotivetouchup.com/spray_paint.asp is what I used for interior touchup. I repainted my ashtray and two aircon vent covers on either side of the dash. This was a near-perfect match of TWO STAGE non-metallic Hawaiian blue 510 paint, requiring a top coat of clear.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-24-2024, 09:06 AM   #5
Yeah, I had the same color mixed at the body supply place for the tool & stowage door on the '71 K/20 Highlander I had. It matched quite well. But matching metallic is a totally different game. And off the shelf color for some other vehicle? Good luck with that.
Here is a peak at the '70 Custom/10 I had with the bed repainted (po) by Maaco. The whole truck had been painted over previously
Old 01-24-2024, 10:28 AM   #6
AnimalMother
Thanks for the suggestions. I ordered some from Jocko's recommendation, I'll report back on how it matches. This is far from a show truck and will be confined to just the firewall, not as if it was being compared to a body panel in direct sunlight, so if it's remotely close it should work great.
Old 01-24-2024, 10:49 PM   #7
jocko
jocko's Avatar
Areas not exposed to the sun for decades (like your firewall) should be a pretty close match. Good luck and would love to see some pics when you're done.
Old 01-25-2024, 08:28 AM   #8
That factory pack mix will be correct and, as Jocko said, on the unexposed to sunlight firewall even better. That's in advance for following up. A thing we need to see more of here.
Old 01-27-2024, 12:49 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Had a spray bomb mixed for the gas fill cover box when relocated my gas tank. Its close I guess.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-29-2024, 02:09 AM   #10
custom10nut
custom10nut's Avatar
Jocko,
I just went to the link you have in your post.
For 1970, they don’t have 504 Medium Olive listed as an option.
However, I checked both 69 and 71, and they list 504, though both years have the 504 code listed by different names.
custom10nut is offline   Reply With Quote
Old 01-29-2024, 07:25 AM   #11
jocko
jocko's Avatar
Can't speak for their website, but 504 was available 69-72 and marketed under various names (between the brochures and SPID), such as willow green, yellow-green, and medium olive - the latter being the most common SPID nomenclature.
Old 01-29-2024, 04:07 PM   #12
Rust_never_sleeps
Rust_never_sleeps's Avatar
Originally Posted by custom10nut View Post
Jocko,
I saw that too. 504 is the same under different names, so unless they've somehow magically calculated the fade year-over-year they ought to be the same
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 01-30-2024, 09:01 AM   #13
twoskies
twoskies's Avatar
someone posted awhile back, Kia has a color on their 2019 line thats a very close match , just a suggestion
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 01-30-2024, 01:15 PM   #14
1969stepside
1969stepside's Avatar
did you use their clear or another type of clear?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 01-30-2024, 01:16 PM   #15
Toro
Toro's Avatar
Was this it? Alien II Pearl AE2
Edit* Looks like this color isn't available for any of the off the shelf DupliColor type products, it's a custom mix. At that point, might as well get the GM 504.
Toro is offline   Reply With Quote
Old 01-30-2024, 01:43 PM   #16
1969LTX
I have tryed to get GM504 formula for "modern paints" without any luck.
Paint shops dont regonice "GM504" at all.
1969LTX is offline   Reply With Quote
Old 01-30-2024, 04:32 PM   #17
Rust_never_sleeps
I had these bookmarked. You might have better luck with the cross-referenced paint codes
https://paintref.com/cgi-bin/paintde...Medium%20Olive
https://paintref.com/cgi-bin/colorco...0Olive&rows=50
There are many posts to read about what a PITA it can be to get a match, even with a custom scan on the glovebox lid, and apparently even more so in 2-stage
Old 01-31-2024, 12:11 PM   #18
1969LTX
Thank you, these links were super helpfull.
