04-27-2014, 11:13 AM | #1 |
Underneath spare tire carrier
Good morning- I picked up a nice used spare tire carrier for my 1966 Burb. The one end has a bolt with 2 jam nuts. My question is-- are the jam nuts to be tightened up to hold the bolt rigid off of the frame, or left loose so it can swing around a little? The piece between the nuts is an old piece of frame as the guy just used a Sawzall to cut it out. Jim
04-27-2014, 11:57 AM | #2 |
Re: Underneath spare tire carrier
I just sold 2 of those. They are kinda hard to find and usually not complete like yours. Nice score.
The square piece is probably not cut from the frame. Both of mine had that square piece and I removed the carriers from the truck myself. I can't remember exactly how the jamb nuts work. I think the FSM doesn't say much either. IIRC, the nuts tighten to keep the bolt from pistoning in the frame hole but they don't actually tighten all the way. The tire jambs up against the underside of the frame and provides tension once it's all tightened up.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-27-2014, 12:52 PM | #3 |
I couldn't figure out how to remove those jam nuts. The top one was inside the frame, I couldn't get a wrench in there. Plus the rust factor. I cut it out and went a differ'nt way.
04-27-2014, 01:32 PM | #4 |
Here's a photo from a longbed I parted out. The whole truck was original. I wish I had a few more angles to show.
I reassembled everything as it was originally. The 2 nuts go above and below the DS lower frame flange. The head of that long bolt acts as a stop.
04-27-2014, 01:38 PM | #5 |
The piece between the 2 nuts was a piece of the frame cut out because he could not get it unbolted. Used the "hot wrench" and got the nuts off. Lugnutz65 -- were the nuts tight against each side of the frame rail? The nuts on mine were seized about 3 inches apart. Jim
04-27-2014, 02:04 PM | #6 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 04-27-2014 at 02:12 PM. |
04-27-2014, 08:06 PM | #7 |
I used the first nut on top of the frame to set the length of the bolt with regard to how low I needed it to hang down. Skinny tire = less bolt, the jamb nut then tightens up under the frame from below to keep everything snugged up good.
04-28-2014, 01:59 AM | #8 |
These may or may not help :
16 pics – under bed spare tire set up ---- also, see these threads in the 60-66 FAQ Index : Section 2D Category : Spare Tires / stock locations / custom locations & mounts / Later model donut spares that fit 6 lugs ---- -W Last edited by Woogeroo; 04-28-2014 at 03:41 AM. |
04-28-2014, 03:32 AM | #9 |
Woogeroo, those pics are awesome! I'm new to these trucks and was having a heck of a time figuring out how the spare was supposed to be mounted. Thanks!
Now I just have to find a carrier for sale. My truck was missing that part when I bought it. Going back to the OP's original question, it looks like your installation has the tire snug against a rail so there's no movement? Also, not trying to thread-jack, but does anyone know is there any difference between the carrier hardware on various years? I have a '66 C-20 fleetside and I'm wondering if a '65 has the same hardware or should I be shopping for ONLY a '66 spare tire carrier? Thanks |
04-28-2014, 04:22 AM | #10 |
Yes you want the tire tight to the cross members if not you WILL be picking up your spare out of the street some where ...I always use the bottle jack to install/remove the tire the bolt nut/loop is kinda a joke its hard as hell to get it tight enough the jack is much easier... If you are not building a museum piece you can get a chain/cable tire lift out of a late model truck they work great I just put one on a trailer ....so nice
