10-19-2019, 08:29 PM | #51 |
Re: Loosenutz's 66 SWB BBW LM4 Build
Installed the bulkhead for the heat and ac lines. Cut the factory fittings off the SSR lines and mocked up the new fittings. Also figured out where to mount the radiator overflow tank.
10-20-2019, 01:56 PM | #52 |
Firewall bulkhead looks like it was made for that firewall pad.
10-22-2019, 07:51 AM | #53 |
Looks like it was meant to be there.
06-13-2020, 12:52 PM | #54 |
Wow, it's been a long time since I updated this thread. Work on this truck didn't stop, I just stopped posting. Big update coming... truck is running and diving now. Starting paint and body soon
06-13-2020, 02:32 PM | #55 |
Taps fingers on the table.....
06-13-2020, 02:47 PM | #56 |
Here's a teaser photo...
06-13-2020, 03:12 PM | #57 |
And another teaser... Yes, I used the gauges, steering column, fuse boxes, and wiring system from the SSR donor. It was a lot of work and modification/fabrication but totally worth it now!
06-14-2020, 11:44 PM | #58 |
Nice work man! Glad you got it together to place where its a runner. 1 nice piece of trim around that cluster and it will look great in there.
06-24-2020, 07:47 PM | #59 |
So I don't feel like going back and posting about the stuff I did over the winter so here's what I've been up to the last few weeks. Pretty much finished up the rear suspension, custom built exhaust, rollpan, and tailgate latches. For the rear suspension I put in an adjustable panhard bar, 5" drop springs, swaybar, and shock relocation brackets with new shocks. The main thing left to do is put in the new crossmember for the trailing arms. I used the stock SSR driveshaft which is a whopping 4.5" Diameter so it barely fits through the stock openning. I clearanced the stocker with a big cutoff wheel to get by for now. I ordered an afermarket crossmember but it turned out not to be big enough for the driveshaft either so I modified it. I'll have another post with those details. The exhaust was completely custom handbuilt by myself. It has a high flow cat and 2 small resonators per side. The sound is amazing. Nice mellow idle and cruise but she barks big time if you hammer it. For the tailgate latches, I went with the hidden spring loaded latches like many people but I did it much more differently. I'll post details below. You can also see the mustang fuel tank that I modified to use the stock SSR fuel pump assembly. Best thing about this is it plugged right into the modified SSR wiring harness. Fuel gauge works and everything. Oh and did I mention the cruise control works too!!
06-24-2020, 07:57 PM | #60 |
Here's how I did the tailgate latches. I put them much lower than most people so they would line up with the indentations that are already in the bedsides. I did this becasue the thought of someone closing the tailgate with the latches extended and slamming them into the new paint in the future made me shudder. I then made some Delrin plastic inserts to fill that location in the bedside (white becasue the truck will eventually be white). It has lead-ins so the tailgate will close even with the latches extended. Time to weld up all the unused holes!!
06-24-2020, 08:03 PM | #61 |
And here's how I handled the crossmember. I bought it off eBay for $100. Chopped the center out. Bent up some new 1/4" thick plates,welded them in, and painted it back up. It's only tack welded in the one picture. Rest assured, I welded the hell out of it. Probably more than was necessary. Still need to install it into the truck.
06-24-2020, 08:25 PM | #62 |
Oh and I built a custom intake last week too. I may have gone a little over board but it's a statement piece for sure!!
06-25-2020, 11:57 PM | #63 |
Made a filler plate to clean up the area where the old tailgate chain brackets were. This should also add quite a bit of strength to the new latches.
06-28-2020, 09:43 PM | #64 |
So I really need to get the windshield in so the truck is street legal. I've driven around some but I'm sure eventually an officer will notice there's no windshield, haha. Before I put it in though I want to paint the dash and the area around the windshield. I wet sanded and painted the dash today. I also have the exterior area around the windshield nearly ready for paint.
07-11-2020, 05:14 PM | #65 |
Finally got the areas around the windshield painted! Can put the windshield in next week and finally be street legal.
07-13-2020, 11:13 PM | #66 |
Took me 3 hours to get it in by myself but it's in! This is the 3rd classic car windshield I've installed and it never seems to get easier. My hands are gonna be sore tomorrow.
07-14-2020, 12:15 PM | #67 |
I'm just glad to be here!
Just went through you whole thread. I really like how the SSR AC compressor and lines work for the install on this swap. Way better than what I had to do with the swap in my son's '84 using the 2002 Truck parts. Might have to look into this with my truck.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-14-2020, 12:27 PM | #68 |
It's not working out as well as I hoped. Going to take some heavy modification to get the lines connected to the condenser. AC is pretty low on my priority list right now.
01-11-2021, 09:49 PM | #69 |
Sneak peek of what I've been up to....
01-11-2021, 11:39 PM | #70 |
Hhmm.....
01-12-2021, 05:26 AM | #71 |
Moderator
Wow, you have some pretty neat stuff your doing on your truck. Very interesting.
01-12-2021, 10:57 AM | #72 |
Love the updates!!! I have been wondering how things were going with you and the build. It appears just fine!! Looks aweseome!! Keep up the great work!
John 3:16 - Saved me... God Bless |
02-12-2021, 09:45 AM | #73 |
Sweet update for this old truck, Nice clean photo's, Thanks.. I like the gauges, very nice. I Looked at an SSR engine swap, not sure I can cut the frame for the power steering.
03-16-2021, 12:37 PM | #74 |
Finally got around to finishing the paint on the cab, box, and tailgate. Feels good to have it back assembled and taking up much less space in the garage!
03-16-2021, 12:40 PM | #75 |
You could switch to a different power steering pump as well. I reinforced the frame where I notched it. Probably stronger than original now. Plus that notch is forward of all suspension mounts so not a stress point. Just the bumper and core support forward of that.
