Old 04-22-2013, 02:51 PM   #1
NewType72
NewType72's Avatar
Exclamation Help need to Drain saddle tanks on dually
I have a 78 lowered crew cab dually and I need to drain the saddle tanks in it as well as the fuel lines what's the easier way to go about this as I don't want to plug up my rebuilt carb and new fuel pump. All advice and techniques welcome.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 04-22-2013, 03:47 PM   #2
meter swinger
meter swinger's Avatar
Re: Help need to Drain saddle tanks on dually
I've done it on a different vehicle by using an electric fuel pump i picked up from the parts store. Hooked it up somewhere before the pump and filter on the vehicle, ran a tube from the pump to a drum. I ran the electric fuel pump off a car battery. Wrapped the electrical connections good and kept the battery a safe distance from the fuel/fumes.
meter swinger is offline   Reply With Quote
Old 04-22-2013, 03:54 PM   #3
NewType72
NewType72's Avatar
I've heard of that one too you have an idea of what the pump cost you? I'm sure mine has a lot of crud in the bottom if the tanks so I'm not sure if I should try and drop them at this point.. Which would be a pain but It could be done.
- Dylan
(209)-985-7721
Old 04-22-2013, 03:56 PM   #4
rs74
rs74's Avatar
That is probably a good idea with the elec. pump. I would just take off the fill hose at the tank and stick in the hose from the elec. pump there. That way you dont have to mess with any other fuel lines. Also if you do it there then you dont have to worry about getting any garbage in your lines.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-22-2013, 04:06 PM   #5
meter swinger
I think the pump was 15$ or so. I have done it by snaking a tube inside the tank too, its kind of hard to determine if your at the bottom of the tank though. I suppose a coat hanger tied to the tube could be of some help.
If your worried about crud you better just bite the bullet and clean them while your at it. Espescially with the new carb.
Old 04-22-2013, 04:31 PM   #6
rs74
rs74's Avatar
I agree. You might just want to drop the tanks and flush them out real good.
Roy
1987 R10 shortie
Old 04-22-2013, 04:53 PM   #7
NewType72
NewType72's Avatar
Alright so get the gas out first with a pump then drop the tanks what can I do to flush them obviously water make the rusting worst and I'm familiar with coatings that you can swish in your tank but getting the crud out is priority
- Dylan
(209)-985-7721
Old 04-22-2013, 05:14 PM   #8
meter swinger
Most common method is about gallon of acetone and a foot or so of medium sized chain. The chain helps knock the scale off. Tie something to the chain so its easier to remove from the tank. Seal off the openings and start sloshing.
Old 04-22-2013, 05:18 PM   #9
NewType72
NewType72's Avatar
Whew buddy that'll e a big tank to slosh
- Dylan
(209)-985-7721
Old 04-22-2013, 06:24 PM   #10
mtnsackett
mtnsackett's Avatar
I use this method all the time when I need to drain a tank, I use a fuel pump that I took out of a buick that I parted out and hooked 30 feet of fuel line to it as well as fused wires with an on and off switch and an old battery, then clip the the end of the hose in a plastic 55 gallon drum that I cleaned out, then when done I can reverse the process. It works slick every time and on the plus side there is no funny after taste.
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world!
mtnsackett is offline   Reply With Quote
Old 04-22-2013, 06:38 PM   #11
NewType72
NewType72's Avatar
I wont have too much fuel in it hopefully any suggestions on a brand of electric fuel pump?
- Dylan
(209)-985-7721
Old 04-22-2013, 06:50 PM   #12
mtnsackett
mtnsackett's Avatar
Anything out of a junk yard would work as you will probably not use it very often or something like this Mr. Gasket Fuel Pump Part Number: 12S from O'reilly auto would work it is under $50
Old 04-22-2013, 07:20 PM   #13
NewType72
NewType72's Avatar
Perfect ill look into a couple places tonight and hopefully have empty tanks by this evening thank you
- Dylan
(209)-985-7721
Old 04-22-2013, 07:29 PM   #14
rs74
rs74's Avatar
What are you trying to get out of the old tank. Old varnished fuel, crud in the tank?
Roy
1987 R10 shortie
Old 04-22-2013, 07:30 PM   #15
rs74
rs74's Avatar
That is a plus when you don't have to worry about that funny after taste.
Roy
1987 R10 shortie
Old 04-22-2013, 08:07 PM   #16
NewType72
NewType72's Avatar
Both well the fuel is probably still good but I'm sure it has rust
- Dylan
(209)-985-7721
drain, fuel, hoses, lines, tank
