Old 03-17-2014, 09:51 PM   #1
Spblack
Spblack's Avatar
5.3 fuel lines
had a few questions for you ls guys... since my 2003 5.3 has a return line on the intake, I don't have to purchase a fuel pressure regulator correct? i havet found much information on the web.
what fittings did you guys use to convert? I found a few, but wanted to see some others. so far I have found these:
http://www.summitracing.com/parts/rus-640850 for feed
http://www.summitracing.com/parts/rus-640860 for return
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 03-17-2014, 11:37 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 5.3 fuel lines
With that setup you do not need a regulator, just a inline filter. I used the Russell fittings for mine, only in black.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-18-2014, 07:12 AM   #3
Lextech
Lextech's Avatar
Re: 5.3 fuel lines
(X2) The regulator is built into the fuel rail on that style system. Those are the fuel fittings you need.
Jeff
Lextech is offline   Reply With Quote
Old 03-18-2014, 10:27 PM   #4
chev3600
chev3600's Avatar
Re: 5.3 fuel lines
Check on the Russell 644123 and the 644113 (if you like black). They are much more secure than the plastic clip on the other style. Seen a few posts about them popping off.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 03-18-2014, 10:54 PM   #5
low57
low57's Avatar
Re: 5.3 fuel lines
What LS swap engine mount plates did you end up using?
low57 is offline   Reply With Quote
Old 03-18-2014, 11:06 PM   #6
Spblack
Spblack's Avatar
Re: 5.3 fuel lines
im using the dirty dingo adjustable ones.
My builds:
Old 03-18-2014, 11:09 PM   #7
Spblack
Spblack's Avatar
Re: 5.3 fuel lines
perfect, thanks. im gonna go with these.
My builds:
Old 03-18-2014, 11:24 PM   #8
Root2812
Root2812's Avatar
Re: 5.3 fuel lines
+1
I boxed my frame rails and used a mustang II kit so I had nice flat frame rails to start with. I ordered these but they are still in the box because I haven't finished the suspension install yet.
http://dirtydingo.com/store/index.ph...=1_206_305_321
My 1950 Chevy build
Root2812 is offline   Reply With Quote
