09-23-2019, 09:12 PM | #1 |
4l80e infi
Guys,
I have been thinking about swapping out the th350 for a 4l80e transmission. Weighing the pros and cons... Any thoughts are appreciated
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-23-2019, 10:12 PM | #2 |
Moderator
Re: 4l80e infi
Massive leap in technology in this swap...
Many questions: Engine it will go behind? Truck size and style? Intended use? You do know you will need a standalone control computer, to control the operation of the trans... DO you just want an overdrive trans?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-24-2019, 09:12 AM | #3 |
Re: 4l80e infi
i understand the stand alone controller I have been looking at these off and on for a while now. Yes i want an overdrive but something that will stand up behind a big cube small block stroker.
I am not concerned with the modifications as i have done several different tranny swaps in my lifetime, how ever i am concerned with the reliability and functionality i guess. I get mixed reviews on the controllers etc etc...
09-24-2019, 09:38 AM | #4 |
Re: 4l80e infi
Love mine except the speedo drive. Maybe I have the cable bent too sharp somewhere but the needle bounces badly under 40 sometimes.
If I had it to do over again, I'd bit the bullet and buy the $600 tailhousing with the mechanical speedo drive cast into it!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
09-24-2019, 08:40 PM | #5 | |
Moderator
Re: 4l80e infi
Hope this helps
09-24-2019, 08:50 PM | #6 | |
Moderator
Re: 4l80e infi
Controllers are a mixed bag... I have had best results so far using...https://www.summitracing.com/parts/tci-302820 which includes the harness... Hope this helps
