09-05-2020, 10:32 PM | #1 |
P/Ns for '83 C30 Crew Cab front (DRW) wheel bearings?
I am collecting parts for installing the drop spindles & springs on my 1983 Chevy C30 Crew Cab 2wd Dually and I will be installing all new parts including bushings, tie rod ends, rotors etc.
Are the following P/Ns correct for the inner and outer wheel bearings? Front Inner: AC Delco S21 (#00457232, 457232) Front Outer: AC Delco 457043 (#00457043, 9431854)
Sent by the random thoughts from the voices in my head... |
09-08-2020, 06:44 PM | #2 |
Re: P/Ns for '83 C30 Crew Cab front (DRW) wheel bearings?
No one????
09-08-2020, 07:36 PM | #3 |
sure it needs bearings and races yet ? lot of good money to spend on most parts that dont need changed out yet .
i just serviced my dana 60 1ton front on my plow truck . had to swap out rotors and the last time it was apart was 2001 ish and prob a good 50-60k miles and HARD miles of mud tires / offroading / plowing / daily driver . and all i had to do was clean / check / repack with new grease and good to go .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-08-2020, 08:06 PM | #4 | |
Anyone know if those P/Ns are correct?
09-09-2020, 10:00 AM | #5 |
I don't know GM numbers. I just used local auto parts replacements. Timkem is what I used if I remember correctly.
